Old 06-10-2009   #1
GregCrowe
Default 1996 ZR1 ???
Supposed to look at a 96 ZR1 tomorrow. VIN number actually even pulls up as a 96 DOHC 5.7L ZR1.
Is there such a thing ?
DECODED 1996 Chevrolet Corvette
Country UNITED STATES
Make Chevrolet
Vehicle Type Passenger Car
Model Corvette
Body Type 2 Door Coupe
Restraint System Dual Air Bag; Manual-Active Belts
Engine Type V8, 5.7L (350 CID); DOHC 32V
Check Digit 3
Model Year 1996
Assy. Plant Bowling Green, KY
Production Seq. Number 102215
Trim Level Base
Drive Line Type RWD
Vehicle Class Small Car
Fuel Type Gasoline
Manufacturer General Motors Corporation
GregCrowe is offline   Reply With Quote
Old 06-10-2009   #2
GregCrowe
Default Re: 1996 ZR1 ???
Now that I think about this. I'll bet it's an LT4 and the VIN decoders are just pulling it up as and LT5. We'll see for sure tomorrow but I'll bet that's the story.
Old 06-10-2009   #3
Federal ZR-1: Ask Goldcylon he is a expert on Federal ZR-1s
Old 06-10-2009   #4
secondchance
No! It must be the almighty GS-ZR-1!
Old 06-10-2009   #5
WVZR-1
Here's I believe the correct VIN: 1G1YY2253T5102215
The car should be black/red, single top and an LT4. It's certainly a "base car"! I mention "base car" only because it's a C60 manual air car also. A "no frills" car for sure!
It's had a water pump at 98K ('07) and a PCM 64K ('02)!
Original delivery: Elpaso Texas
Does that sound like the car? I'd guess the car either in OKC or very close!!
Old 06-10-2009   #6
GregCrowe
Yep, bingo!
It was showing up on the dealer sale tomorrow as a DOHC 5.7L V8. I did a VIN decoder on it and it also showed a DOHC 5.7L V8. I looked up a few LT4's and found similar VIN's....... that's what it is.
Old 06-10-2009   #7
WVZR-1
Google is a "VERY GOOD" decoder! You can Google any VIN and if it's a legitimate VIN it will decode for anything that carries a 17 digit VIN since '81. If it's '81 or newer and Google doesn't recognize it there IS something wrong with the VIN and likely the car!!
I tried the VIN after I put it together and all I got from several were 5.7 V8 16 Valve. The services performed are from a quite reliable source!!
Old 06-10-2009   #8
DaveK
http://www.citychevrolet.net/used-in...d61c3b6baf5e13
Is this the one? Not a ZR-1, doesn't even look like an LT-4 from the description there.
1991 #1516 Black/Black
davidmkelly.com
Author of fast-paced, sci-fi thrillers.
Old 06-10-2009   #9
Kevin
Kevin's Avatar
1gyy = base vette
1gyz = zr-1
Old 06-11-2009   #10
bdw18_123
The picture of the interior shows a manual transmission. If it's a '96, then it's definitely an LT4. I think the description below the pics that says '4-speed automatic' is probably wrong.
