05-03-2009 | #1 |
Change Oil Light Reset Procedure
Hey Guys:
I looked all over for the oil change reset procedure and even looked in the maintenance section and I still can't find the procedure to reset the light. Can someone post it for me please?? TY!
Tom MovIt Brakes USA [url]www.TFEnt.com[/url] |
05-03-2009 | #2 |
Re: Change Oil Light Reset Procedure
Key on, Engine off.
Press ENG MET within 5 second press it again. Press and hold GAUGES button. CHANGE OIL light will flash. Hold until CHANGE OIL light stops flashing. When it stops it is reset, Rich
REBelZ '92 ZR-1 Yellow/Black #031 Last edited by rebelz; 05-03-2009 at 09:43 PM. Reason: Caps |
05-03-2009 | #3 |
Thank u!!!!
05-03-2009 | #4 |
yw!
REBelZ '92 ZR-1 Yellow/Black #031 |
05-03-2009 | #5 |
OK where is the gauges button?? Its a 1990.
Yep they changed things around a little starting in 92 button wise.
Tom MovIt Brakes USA [url]www.TFEnt.com[/url] Last edited by GOLDCYLON; 05-04-2009 at 12:49 PM. |
05-03-2009 | #6 |
for 1990 :1. key on, engine off
2. press ENG MET and release. within 5 seconds press and release ENG MET again. 3. within 5 seconds of step 2 press and hold RANGE button. the CHANGE OIL light will flash. 4. hold RANGE button until CHANGE OIL light stops flashing and goes out. |
05-03-2009 | #7 |
Thank u!
05-04-2009 | #8 |
The procedure is in the owner's manual.
04-18-2012 | #9 |
Any clues on how to proceed if this doesn't work?
I've tried every timing possible on the two hits to ENG/MET and can't get a flashing "CHANGE OIL", just stays steady. Thanks, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
04-18-2012 | #10 | |
Did you hit the range button and hold which is the final button for the procedure on your 91?
