Old 03-26-2009   #1
Default Valet Key on the bay
hey guys,
Saw this and some people wanted a valet key....
http://cgi.ebay.com/ebaymotors/1990-...Q5fAccessories
Only thing is, seller says it's a 90 to 95 key.... I think there are 2 keys, right? 1990 and 1991 and 1995?
Old 03-26-2009   #2
Default Re: Valet Key on the bay
Originally Posted by ZZZZZR1 View Post
hey guys,
Correct the 90 key is different than the 91-95 key.
Old 03-26-2009   #3
right 2 styles, in the text of the auction it is from a 1990
Old 03-26-2009   #4
Aurora40
Aurora40's Avatar
The emblem on it is definitely 1990. I don't recall the keys having teeth cut on them though? I guess I'll have to go look at mine again...
Bob Saveland
Former owner of #2517
Old 03-26-2009   #5
Kevin
Kevin's Avatar
the 90 powerkey is a blank door key
Old 03-26-2009   #6
bobbyhi
bobbyhi's Avatar
My power key on my '90 has teeth cut (both keys). Never tried on the door?? When I replaced the whole assembly with NOS the teeth were cut on it also.
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 03-26-2009   #7
Kevin
Kevin's Avatar
it's been some time since i've seen my power key, cars been sleeping for months, but i remember it having 'teeth' cut into it also not like the ignition key but it wasn't flat either. however i only remember them being on one side. I'll check when i get home. Gordon Killabrew was the one who told me about the power key on the 90 being a blank door key
Old 03-26-2009   #8
which probably meant you can use a blank door key and have it cut for the power key. all 3 of the 90 power keys I have are cut.
Old 03-26-2009   #9
Gunny
Gunny's Avatar
I'm pretty sure that all 90 power keys are cut the same from the factory and that a blank door key can be cut to be used as a power key. I don't think I remember seeing a "blank" power key.
George Jones
Founding Member #14
www.zrwon.com
Old 03-26-2009   #10
WVZR-1
I doubt a "blank key" would work but who knows!
'90 key info: The key's "knock out" is a code "91C9" and is on a D keyway. Any D blank door key cut to "91C9" will work. I use a D blank "padded" key for mine for everyday use!
'91+ key info: "73L0" and is cut on an H keyway.
