Old 03-25-2009   #1
Default Clutch switch?
Is this the switch you need to jump?
Old 03-25-2009   #2
bobbyhi
bobbyhi's Avatar
Default Re: Clutch switch?
Didn't show the pic on my computer
Old 03-25-2009   #3
I know this is for stereo equipment, but what the hell is this?
Old 03-25-2009   #4
Aurora40
Aurora40's Avatar
The links appear to be from your yahoo email. They will not show up for the rest of us.
Old 03-25-2009   #5
I knew that
Old 03-25-2009   #6
first picture..
NO, that is the Cruise Switch. the Clutch safety switch is 2 heavier gauge wires
off the switch they are both black, on the harness side.. one is yellow and one is purple I think
Second Picture, that is a Passive Crossover, apparently your front speakers are components, so that box splits the highs and lows for the tweeter and midrange speakers
Old 03-25-2009   #7
That splits your "he" tweeter from your "are" components!
Old 03-25-2009   #8
Thanks..I fixed my typos.. damn having a cold and being tired at the keyboard don't mix
Old 03-25-2009   #9
Hey just having fun being a smartazz Jeff!
Good luck with the cold!
Old 03-25-2009   #10
Kevin
Kevin's Avatar
Pull drivers side hush panel. Find Purple wire that goes to clutch
switch. Look at switch and note the color of wire coming back
up.(Yellow??) Will be able to jumper them right there. I used a 3 in
wire with terminals on the end and unplugged the wires going to switch
and plugged in the jumper wire. Use a 12 ga wire at least as it does
carry a heavy current load which is why the switch fails, it gets hot
and the resistance across the points stops current flow.
