03-11-2009 | #1 |
Oil Leak
What is the part number for the sensor underneath the oil filter housing? How much of a pain is it to replace? It is leaking oil when the engine is running.
TIA |
03-11-2009 | #2 |
Re: Oil Leak
From our distinguished friend and colleague guinnessdude.
Check your local auto parts store and buy a Duralast PS206 or equivalent. Make sure you buy the one that states it is for a car with gauges...not just the light. The GM Part # is:12555492 NIEHOFF OP24471 $25.99 DURALAST PS206 $9.99 VALUCRAFT OP8165 As far as difficulty, nothing to it.
1990 ZR1 #2574 Medium Quasar Blue Metallic 1 of 19 Last edited by 1990 quasar blue; 03-11-2009 at 05:16 PM. Reason: added info. |
03-11-2009 | #3 |
Re: Oil Leak
That is the wrong sensor, that is for the sensor that control the gauge. There are two other sensors on the underside of the oil filter housing. Oil temp, and oil pressure sensor for the ECM.
Oil temp sensor - 90-91 10096136 92-95 10096181 Oil pressure ECM - 25036935 |
03-13-2009 | #4 |
Re: Oil Leak
It is leaking on the one you see just left of the oil filter housing
03-13-2009 | #5 |
Re: Oil Leak
Should be the fat and stubby sensor. Have fun changing it. |
03-13-2009 | #6 |
Re: Oil Leak
04-01-2009 | #7 |
Re: Oil Leak
04-01-2009 | #8 |
Re: Oil Leak
Remove the oil cooler hoses and snake your arm through the gap. Jack up the motor on the right side after undoing the nut for the motor mount and see if you get enough room.
04-04-2009 | #9 | |
Re: Oil Leak
There isn't any other way? Was hoping there was a special tool or extension that would work without having to move the motor. |
04-04-2009 | #10 | |
Re: Oil Leak
Actually, there is another way. Buy a round trip ticket for Jeffvette, feed him well, introduce him to some new avatar girls, and pay him a reasonable fee and he'll show you exactly how to do it. George |
