Old 03-09-2009   #1
Default Compression Test
Anyone have normal specs for LT-5 compression or tested their car?
Old 03-09-2009   #2
Default Re: Compression Test
You break the black one already??
Old 03-09-2009   #3
checking condition of the engine.
Old 03-09-2009   #4
Ah, is there something that has you questioning it?
Old 03-09-2009   #5
Engine not at temp, will retest,
210 on left side
240 on right side
went back after testing right side to validate # and restested left and got 210.
Old 03-09-2009   #6
jonszr1
jonszr1's Avatar
dont know if altitude plays a part in testing compression. my black car tested at 175 -180 cold my altitude is 4000 ft . did they all test 210 on the left side / did you have the plenum and inj housings off? if not was the throttle held open all the way?i wonder if the cam s on tthat one side are timed different. dont know if that is possible ,just sharing thoughts .hope it helps
Old 03-10-2009   #7
flyin ryan
flyin ryan's Avatar
210 on left side
240 on right side
pretty high...
Old 03-10-2009   #8
Pete
Pete's Avatar
Lee,i have done compression test with almost every cam timing i have tried.
It's been a while i can't rememmber.
I have to find the paper work.
If i find the paperwork i can almost tell you where your cams are timed at.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-10-2009   #9
Nick
Originally Posted by flyin ryan View Post
pretty high...
Interesting comment, Ryan. Mine are as follows (with 70,000 miles on the clock; test done per the '94 service manual):
#1: 220
#2: 220
#3: 215
#4: 210
#5: 215
#6: 210
#7: 215
#8: 215
I'm not so sure the numbers themselves are that important. What is important, at least to my mind, is the consistency between the cylinders. But, Ryan, you would know more than I!
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 03-10-2009   #10
Pete
Pete's Avatar
I also remember 210's - 220.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
