Old 02-27-2009   #1
Sgreg
Sgreg's Avatar
Default WTB: ZR-1 EPROM
I am looking for a 91 ZR-1 eprom part # 16193416 AKA 3417 BFXB. If you have one for sale, please PM me. Also interested in finding a blank Eprom 27C256. Thanks.
Sgreg is offline   Reply With Quote
Old 02-27-2009   #2
Default Re: WTB: ZR-1 EPROM
Sgreg,
Do you need the stock prom or a copy of it? BTW, I have a 27c512.
Old 02-27-2009   #3
Sgreg
Sgreg's Avatar
I would prefer the stock prom. Is the "512" the same as the 256 only faster transfer ? Thanks, please PM me with prices.
Old 02-27-2009   #4
The 512 is just a prom with 512kb rather than 256kb. Same chip, more space. What are you using it for?
Old 02-27-2009   #5
Sgreg
Sgreg's Avatar
To download a performance prom. I really need the stock eprom more than the blank.
Old 02-28-2009   #6
Tyler Townsley
Do you have the capability to burn the calibration? I think Todd P has a stock 91 calibration. Unless you use a Moates adapter to use an eeprom you need the whole prom carrier with a prom that has your needed calibration burned into it. Another way is to cantact Marc H and have a custom calibration done by him, I believe if you send him yours he will program it to your car.
Tyler
Old 02-28-2009   #7
Sgreg,
You have two ways to go. Either get a stock prom, erase it and upload your new cal OR, get a Moates adapter and install an auxiliary chip onto the stock prom
Old 02-28-2009   #8
Tyler Townsley
Sgreg,
The advantage to using the adapter and an eeprom is that it can be erased and programed using lower voltages. The stock prom has to be erased using a UV device and programed using a higher current burner. It is usually cheaper and easier to have someone who already has the equipment do it for you.
Tyler
Old 02-28-2009   #9
Tyler
I erase both proms using UV. And I upload the cal on either one with the same burner settings.
Old 02-28-2009   #10
Tyler Townsley
You can erase and program the eeproms (AT29 series eeproms) using this usb programer.
http://www.moates.net/product_info.p...roducts_id=197
It will not erase or burn the 27 series eproms, but you can read the calibration. For that I use an old Needham unit. Needham is gone out of business.
Tyler
