Old 02-15-2009   #1
secondchance
Default Oil Cooler Line
Anyone know where I can find one at reasonable price? This is for a 94 (I thinkt 93-95 are same).
Old 02-15-2009   #2
xlr8nflorida
xlr8nflorida's Avatar
Default Re: Oil Cooler Line
I'd get your originals redone by a company that specializes in hoses and AC.
Old 02-15-2009   #3
I agree that can be done at a reasonable price in Stainless with nice fittings. Unless this is a NCRS deal.
Old 02-15-2009   #4
secondchance
It's my daily driver.
Old 02-15-2009   #5
tccrab
tccrab's Avatar
Here's my solution:
http://www.zr1netregistry.com/forum/...5&postcount=14
TomC
"Crabs"
Old 02-15-2009   #6
Originally Posted by tccrab View Post
$200 for the set Tom?
Old 02-15-2009   #7
tccrab
tccrab's Avatar
Actually, a little less.
$192.75
TomC
"Crabs"
Old 02-15-2009   #8
Can they be easily made?
A z brother in Va needs some made "asap".
Can I get a number to give?
thanks
Old 02-16-2009   #9
tccrab
tccrab's Avatar
David:
Sierra Tractor:
530-676-9920
http://www.sierratractor.com/default.htm
Ask for Nettie, tell her it's another set of the "Fancy Corvette" hoses.
You will need to have the old hoses sent over here so that they can cut the old hoses from the manifold and weld male fittings on to them.
Good luck!!
TomC
"Crabs"
Old 02-22-2009   #10
Scrrem
Scrrem's Avatar
thanks
David,
Were you ever able to run down a local shop that would do this. Just spendt today chancing one of my oil leaks. My oil cooler lines are leaking bady, got to get this fixed. The hoses should be faily easy to get fabricated, but getting the cooler ends treaded will be the trick. Let me know
Thanks
Rich
