Old 01-17-2009   #1
jonszr1
jonszr1's Avatar
Default Coreys tune is first rate
well i knew that the tune wasnt right on my 92 so off i drove to coreys for a ck up . just alittle 1500mile treck down the road. well car made 373 base line and when he was done 3 hrs later she was at 395. he also was a little sneek .hehe as he did alot of part throttle tunning that i dint find out about till i did my gas mileage figures once home . on the way out i got 23.8 which for having 3.92 gears not too bad . but then on the way home thought my gas gauge was acting up as i kept over estimating when i went in to fill up ?????/ . when i sat down and figured it out i got 26.8 oon the way home .i tripled cked thinking i made a mistake . no mistake though . and wow am i happy . morale of the story if you can go get corey to tune your car your baby will be very glad you did . it shows how much he really cares to take the time to make the beast be all she can be .Corey thanx you are 1 in a million
Old 01-17-2009   #2
Bell Curve
Bell Curve's Avatar
Question Re: Coreys tune is first rate
How much does he charge for a tune and does he have chips like Mark Haibeck for the tune?
Bell Curve is offline   Reply With Quote
Old 01-17-2009   #3
jonszr1
jonszr1's Avatar
Default Re: Coreys tune is first rate
it would be best to call corey 210 867 6286 for a direct quote . i do believe he has an extensive log of files of different tunes .as he keeps every tune he does . the more complete the info you give him the closer he can come for your car . many tuners only deal with wot. on the tune he works over all parts of your tune inc part throttle and cruize tune ie highway cruize. him doing this increased my fuel milage on the way home 3 mpg . the car seems to run cleaner seems more responsive when i start to get on it . he also will keep your tune very safe giving up a few hp so that the motor stays happy.all i can say is that in my opinion he is the best at tunning not only zr1s but anything that is brought before him . he takes every car he gets as his own and goes to great lengths to tune all aspects of the car.
