Old 12-08-2008   #1
Harold Broerman
Default looking for airbag sensors
need airbag sensors for 90 zr-1.gm part#10094613 call Harold days 6am-2pm 1-800-475-5431
Harold Broerman is offline   Reply With Quote
Old 12-08-2008   #2
flyin ryan
flyin ryan's Avatar
Default Re: looking for airbag sensors
you can maybe try: Airbag Systems, Inc.
1414 Comanche Dr.
Allen, Texas
75013
i think the web site is: www.airbagsystems.com
Old 12-09-2008   #3
65ZR1
Are these the ones that mount on the front frame rails? If so I have one.
Kris
65ZR1 is offline   Reply With Quote
Old 12-09-2008   #4
Harold Broerman
To 65ZR-1, yes, frame rail ,right side. how much do you need for it ? thanks, Harold
Old 12-09-2008   #5
65ZR1
I have the sensor in front of me. It says P/N 10177901 on it and 10408319. Im positive this came off the front frame rail but Im not sure which side. Can you check this with yours? I would take 20.00 for the sensor. It is in mint condition. I also have the air bag sensor that mounts under the dash for 15.00 if you need it. Shipping would be extra.
Not to kill a sale, but have you tried cleaning your sensor. I thought I read somewhere that these often go bad but all you have to do is remove it, clean any rust on it and the frame and reinstall it.
Good luck!
