Old 12-02-2008   #1
jonszr1
jonszr1's Avatar
Default weepy coolant hose , the one with the plastic clips
is weeping .the o ring doesnt look bad . you can kinda wiggle her around though . do you buy a tiny bit bigger o ring ?????/ thanx for any help
Old 12-03-2008   #2
8upZR1
8upZR1's Avatar
Default Re: weepy coolant hose , the one with the plastic clips
If its the fitting with the clips that attaches to the thermostat housing, where the heater hoses go, it can be unscrewed and a new one screwed in. The fitting is std GM and available at pepboys and such for a few $$. I had that leak and it wasnt too bad, annoying, but not too bad to fix.
8upZR1 is offline   Reply With Quote
Old 12-03-2008   #3
jonszr1
jonszr1's Avatar
wow ,thanx a bunch i though it wwould be another of the NLA deals
