Old 08-06-2005   #1
RiceEatingZR1
RiceEatingZR1's Avatar
Default Short Shifters ??
I am considering getting a short shifter for my Z. However Im not sure what one is better between the Hurst or B&M. any recommendation? Also how difficult are they to install
RiceEatingZR1 is offline   Reply With Quote
Old 08-06-2005   #2
Gunny
Gunny's Avatar
Default
I've got the Hurst and it was a very good mod for me. The B&M is supposed to have a shorter throw but also requires more effort and precision on the driver's part .... I'm sure that could be an advantage for some at the track. But the Hurst is smooth & quick. You do lose the reverse lockout, but I consider that a plus.
Installation is fairly straightforward and while it would be much easier with the tranny out, it can be achieved without dropping the tranny. Two people and a lift definitely make the job much easier. Good luck.
Old 08-07-2005   #3
bigd
bigd's Avatar
Default
Hurst shifter here. Very happy with the feel. Aaron Scott did the install. Losing the reverse lock-out has not been a problem. I also installed a "pistol grip" style knob from MGW. Very good quality.
bigd is offline   Reply With Quote
Old 08-08-2005   #4
RiceEatingZR1
Default
I was worried about Losing the reverse lock-out only because I have a bad habit of grabbing the shifter from the side and pulling and I am worried about pulling it to far over and going into Reverse. but it sounds like no one has that problem.
Old 08-08-2005   #5
91King
91King's Avatar
Post
Hurst shifter here as well. Huge improvement over stock. Losing reverse lockout is a blessing as far as I am concerned.
91King is offline   Reply With Quote
Old 08-09-2005   #6
Jim Jones
Jim Jones's Avatar
Location: I'm in a constant state of euphoria in the Z!
Default
What are the advantages of having a short shifter unless you are at the track? Or is it just personal preference?
Jim Jones is offline   Reply With Quote
Old 08-09-2005   #7
ZR1 MK
Default
Much more precise and controllable.
I have the B&M, but it was awful until I raised the shifter height 3/4 inches and now is great. The Hurst has gotten much better reviews over the years. I figure there isnt anyone else who moded the height of the B&M as I have and this will account for the reviews.
ZR1 MK is offline   Reply With Quote
Old 08-09-2005   #8
RiceEatingZR1
Default
Thanks For all the info guys sounds like the Hurst is the way to go.
Old 08-18-2005   #9
Nick
Default
I am running the Hurst shifter. Its an excellent low budget mod. The installation can be a bit tricky. It would be nice to have had a helper, but I managed it all by myself and it took me about 8 hour total.
Old 08-18-2005   #10
bobbyhi
bobbyhi's Avatar
Default
I also have the Hurst. Really like it alot better than the original. Don't miss the reverse lock out at all. I do not take the Z to the track so this must be a personal thing.........
