Old 10-28-2008   #1
Default W/B Igntion Coil Tray
Anybody have the tray and harness connectors for the ignition coils?
Old 10-28-2008   #2
Jeffvette
Default Re: W/B Igntion Coil Tray
You mean the coil base, and which harness connectors?
Old 10-28-2008   #3
Jeff,
Yes the base and the connectors that plug into DIS module under plenum. I don't recall if they were hard-wired to coil base or not. Actually, if you had just the pig tails, that would be fine. Thx.
Old 10-28-2008   #4
limey
If you need just the wire connectors, you can order them from any dealer by the part #'s listed on our site. They have pictures to show what is what.
http://www.whiteracingproducts.com/i..._description=1
limey is offline   Reply With Quote
