Old 10-26-2008   #1
65ZR1
Default Parts for sale
Trying to find a good home for some parts I no longer need. Im not sure about some of the prices so feel free to make an offer. The 94 parts are from a car I parted out a few years ago. It had about 8000 miles.
rear rotors - mint factory units 50.00
fuel boot - 10.00
drivers power window switch - 40.00
2 intake belows and clamps - 40.00 each
rear ABS sensors - 10.00
ABS hydraulic unit and computer - 150.00
damaged thermostat housing - someone tried to repair the threaded heater line and melted it, I have bored it out and it neads a threaded plug welded in. 100.00
ZF clutch fork with ball and inspection cover - 50.00
AIR valve and lines
Power steering lines - mint condition 50.00
wiper motor - no cover 50.00
stock flywheel bolts - 15.00
negative battery cable - 30.00
vacuum pump to motor line SOLD
all HVAC sensors SOLD
front and rear sway bar links - 25.00
rear sway bar
front and rear e-brake cables - 60.00
exhaust sheilds - SOLD
PKE antennas and module - 40.00
LTPWS module - SOLD
SIR module and sensors - 25.00
Power seat relays
Power seat tracks - drivers is twisted because the floor buckled
Power key module - 150.00
ECM holder and wire cover - holder has slight damage - 40.00
heater valve servo - SOLD
blower motor driver - SOLD
FX3 module - 100.00
TPS interface module - 20.00
ABS module mounted to trans tunnel - 15.00
Power mirror control - 15.00
EVAP solenoid - SOLD
ZF shifter knob and pattern - 35.00
AC bezels 20.00
Rear view mirror - 20.00
90 AIR valve and blower motor - 50.00
90 Vacuum hoses - run along passenger wheel well 20.00
90 Steam lines 30.00
Prices dont include shipping.
65ZR1 is offline   Reply With Quote
Old 10-26-2008   #2
Pete
Pete's Avatar
Default Re: Parts for sale
I will take the Thermostat housing. if it's complete (both halfs).
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-26-2008   #3
Hello interested in
all HVAC sensors
exhaust sheilds - free
LTPWS module - 40.00
heater valve servo - 15.00
blower motor driver - 20.00
EVAP solenoid - 10.00
Hi interested in the above are they still available?
Old 10-27-2008   #4
I'll take fuel boot if its the black gasket surrounding the filler neck under the fuel filler hatch.
Also want rear view mirror. Do map lights work and are mirror joints tight?
Old 10-27-2008   #5
John Boothby
John Boothby's Avatar
Do you happen to have the Lumbar support pumps; lines and switches?
If so, I would be interested.
John Boothby is offline   Reply With Quote
Old 10-27-2008   #6
65ZR1
Pete
It is missing the part that covers the thermostat.
Old 10-27-2008   #7
65ZR1
Goldcylon
Its all still available. I am heading over there Tuesday night so I will get the AC sensors toghether and let you know what I have. I will also snap a pic of the vacuum line so you can confirm it is what I think it is. Its been a few years since I parted the car out.
Old 10-27-2008   #8
65ZR1
The switches are the ones in the console, right? If so they are sold. What I have is the wire harness with the relays. Im sure I have the pump. I will check Tuesday night.
Old 10-27-2008   #9
65ZR1
Mirror joints are tight but Im not sure about the lights. I will hook them up tomorrow night and check them. We are talking about the same fuel boot.
Old 10-27-2008   #10
Thumbs up Re: Parts for sale
Originally Posted by 65ZR1 View Post
Goldcylon
Ok thanks let me know
