So guys,What do you think Cancelling the front Sway Bar?
any one did that? what side effect..? ![]() Last edited by HADI-ZR1; 10-08-2008 at 12:00 AM. |
![]() Join Date: Dec 2004
I could be dead wrong about this "generalization"....but uaually on a front engine/rear drive chassis if you disconnect the end links on the front bar you will end up with more over steer in general, and if you are on the power & turning in to a corner, you will have "power on over steer" ...... usually the front end wants to wash out to the outside of the corner unless you put a good deal of opposite 'lock' into the front wheels, I think......if you have ever watched dirt track oval racing you will see a good example of power on over steer.
![]() Join Date: Jan 2008
If I may Ask??? Why do you want to disconnect the sway bar??? Are you not happy with the corner handling ??
he might be wanting to disconnect it to go drag racing . do this really can free up front end lift off the line hence increased traction
Yup.
It's an old drag racing trick. My old '67 Camaro had no sway bar and 90/10 shocks up front. The front end lifts to the sky at initial hammer drop and slowly goes back to level about halfway down the track. If set up correctly, this trick can make some nice improvement in the 60' times. You wouldn't want to drive a car like this on the street. The first time you fed any throttle at all into a corner you'd be buying a new car. ![]() Hadi, it's not something you should even think about doing to your 'Vette. TomC "Crabs" |
#6 | |
and this is not why i want to cancel it, buddy. but I have spring rate 500 lbs (front) ,so i am not in lean ,and my car is lowered, so there will not be much force in cornering, hence i feel The front sway bar is Rabish! ![]() I need more opinions on this trick. thanks. I will take the Z for test when i done with it. Last edited by HADI-ZR1; 10-10-2008 at 05:27 PM. |
I post this from other forum member just for Info. exchange!
It's my understanding that front anti-sway bars actaully contribute to understeer. They force you to back off on the speed in a turn before you are actually out of lateral grip. It makes the car "safer" for less experienced drivers, which is why most cars come with them, but they don't actually improve handling beyond a certain point. I learned a lot of what I know from a VW/Audi/Porsche suspension expert up in MA (Dick Shine) and he doesn't include front sway bars in any of the custom suspension systems he built. He usually recommends leaving the stock bar, definitely NOT a thicker front bar. He suggests removing the front bar altogther in some cases for experienced drivers. |
#9 |
Just leave it on.
#10 |
Agreed. You've yet to say what you're trying to fix!
