Old 10-03-2008   #1
kenthompson
kenthompson's Avatar
Default Well, they're gone!
Jerked out the secondary throttle blades tonight. I think I bent every one getting them out.
Waiting on parts now!
KT
1990 Grey/Black
Too many for the sig.
kenthompson is offline   Reply With Quote
Old 10-03-2008   #2
Default Re: Well, they're gone!
I just removed throttle plates and left everything else in. Tie wrapped secondary vacuum mechanism OPEN.
Old 10-03-2008   #3
bldavis11
Dumb question. Am I correct to assume that you need a custom chip to run these open all the time? Seems like the fuel ratios would be all jacked up.
bldavis11 is offline   Reply With Quote
Old 10-04-2008   #4
You do need to modify the calibration so secondary injectors
are always on. At closed throttle, they'll be off. VE tables
should be revisited also.
Old 10-04-2008   #5
bldavis11
I just never heard of any one "ripping them out." I miss read the OP though and thought he was just going to fire it up. I was being subtle at suggesting the need for a chip. Dumbass me should have read the post more carefully!
Old 10-04-2008   #6
John Boothby
John Boothby's Avatar
What will this do regarding state (NV) emission testing? Seems like the car may run too rich to pass? I have a DRM chip and the car will not pass (too rich) with the power key on FULL POWER (Secondaries open).
JB
1990 #148 Red/Saddle
Haibeck AYBKG5 Chip/RC Engineering/Flowmasters/K&N/Samco/Fuzzy Dice
:cheers:
John Boothby is offline   Reply With Quote
Old 10-04-2008   #7
kenthompson
John,
Right now, I don't know what it's going to do to the emissions testing. I turn the key off anyway. It won't pass emissions testing in Clark County right now either due to some other issues with over-sized injectors and lack of chip management ( read, I haven't fixed the chip to compensate for the 24# injectors yet)
I'll let you know what happens.
1990 Grey/Black
