Old 09-30-2008   #1
ZR-FUN
Default Spark Plug Gap
OE gap is 0.05. I'm wondering what the best gap for a stock ZR-1 ('90) w/ NGK iridiums is... I hear a lot of different opinions from the GM for plugs...
Edit: Maybe this should be in the tech section.
ZR-FUN is offline   Reply With Quote
Old 09-30-2008   #2
Default Re: Spark Plug Gap
I don't know that this will help as I use the stock GM replacement plugs, the 402's, in my '90, but I use 35 as my gap as per the FSM.
Old 09-30-2008   #3
jonszr1
jonszr1's Avatar
first off be very carefull when cking the gap on these plugs . i use a ring gap tool and go until it just bearly touches . i found with these plugs that 45 thou is max for me .i settled on 40 thou for the ngk. hope this helps
Old 09-30-2008   #4
ZR-FUN
OE specwas 0.05. then they said use 0.035 as your doing. for the rapid fires they said 0.045. so its confusing.
But, NGK's come at different factory gap. And a different gap for each type of plug they make for the LT-5. so i was wondering what was best for the NGK iridiums.
So, 0.04 for the NGK iridium?
Old 09-30-2008   #5
jonszr1
jonszr1's Avatar
yes ,being an old drag racer i have gotten used to reading plugs and at .40thou. they seem to burn the cleanest . jmho
Old 09-30-2008   #6
karterdon
karterdon's Avatar
keep in mind that you do not have a high performance ignition system - So your coils can only produce so much voltage to jump the GAP - the bigger the gap the more umpf you need - So I would stay between the .035 - .040 gap. The plug is not the issue - Its the ignition system we have.
Don Yoakem
91 - #267
Dark Red Met.
karterdon is offline   Reply With Quote
Old 10-01-2008   #7
jonszr1
jonszr1's Avatar
i agree . its the coils that limit the gap
Old 10-01-2008   #8
Pete
Pete's Avatar
1990 has .035 from the factory.
I wouldn't go more then that with stock ignition..
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 10-01-2008   #9
jonszr1
jonszr1's Avatar
pete , just wondering why is the 90 different than the other years ?
Old 10-01-2008   #10
Pete
Pete's Avatar
It's 1990-1992 have .035 factory specs.
1993-1995 are .050 factory specs.
I think for idle quality and they went with those 100,000 mile spark plugs,not 100% sure.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
