09-20-2008 | #1 |
Catch Can hookup
I have my catch can hooked up off the PCV system, wondering if I should have them hooked up off the breathers coming from the heads into the air horn?
LGAFF 92 ZR1 #234 |
09-20-2008 | #2 |
Re: Catch Can hookup
how much oil you using?
09-20-2008 | #3 |
I have not measured it but seems like alot......I pulled the plenum to fix a vac leak and it was still coated in oil, even though there was oil in the catch can.
Wondering if the vapor is hitting the TB blades and condensing back into liquid??????????? LGAFF 92 ZR1 #234 |
09-20-2008 | #4 |
I think the one in front of the TB, i.e. open to ambient pressure, is what allows air into the system. Presumably air shouldn't flow back to the air horn, though I think I've noticed oil in the air horn in the past as well.
09-20-2008 | #5 |
Haibeck said that oil comes back up through the engine, maybe this was what he was referencing?
LGAFF 92 ZR1 #234 |
09-20-2008 | #6 |
The pipes going into the cam cover are a fresh air intake. Under extreme circumstances should you actually have oil flowing from the cam cover to the air horn. If you did have that issue, the last worry would be oil in the plenum.
You could fab a system up to cap of the air horn inlets, and then use a another catch can with a open element breather on the top. The PCV system is the main culprit, as it is a direct tie in with the plenum. |
09-20-2008 | #7 |
Bob is correct. The tubes from each cam cover to the air horn is for the filtered purge air to the crankcase.
I believe the catch can should be installed into the line between the PCV's & the plenum. That's where oil in the plenum comes from, sucked up through the PCV's vi the PCV system vacuum source. Here's a drawing I made to show how we are going to do it on the Raptor TT system.
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 09-20-2008 at 06:53 PM. |
09-20-2008 | #8 |
The air horn is dry but I still have puddling in the TB.
LGAFF 92 ZR1 #234 |
09-20-2008 | #9 |
The TB is where the PCV comes in. Maybe your catch can isn't catching all of it?
09-20-2008 | #10 |
you might want to get in contact with corey and ask him what they did to bob halls car to solve this problem
