Old 08-29-2008   #1
FLT4PWR
Default Engine removal-need help.....please
Hey guys,
I am new here, though I have posted & introduced myself in the General Forum. ( for background on me and the car, http://www.zr1netregistry.com/forum/...ead.php?t=6260)
Anyway, I have decided to break the rebuild into sections.
First, I'd like to remove the engine so I can go about redoing the interior and body stuff while the engine is being tended to...(I hope to eventually get into contact with Aaron at SGC (i've tried several times to no avail), since he lives only about an hour away...and, I'm not real sure what if anything I will have done to the motor)
Is there an existing write-up somewhere as to the steps in properly removing the LT-5? I did some searching, but didn't really come up with anything...so, any tips or suggestions would be welcome...hopefully I can return the favor soon.
(suggestions on thiing s to do with the engine while it is out are welcome as well)
thanks again.
FLT4PWR is offline   Reply With Quote
Old 08-29-2008   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Engine removal-need help.....please
Get a set of ZR-1 LT5 Service tapes
Engine removal is well covered
Contact Al Whittier
old.hot.rodder@verizon.net
Old 08-29-2008   #3
tccrab
tccrab's Avatar
Bill:
Howdy!!
There's a write up over on the front page:
http://www.zr1netregistry.com/engine.htm
And also a write up on rebuilding the engine without removing the block:
http://www.zr1netregistry.com/lt5rebuild.htm
Here's a write up with pictures at Corvette Fever:
http://www.corvettefever.com/howto/16798/index.html
Since you're going to the trouble of getting it out, you might as well pony up for an upgrade or two.
Getting the top end ported and powder coated is certainly a must do.
Talk to JeffVette (Jeff Flint) at PNW ZR1's. He's the man for porting/polishing & powder coating: (tell him I sent you)
http://www.pnwzr1.com/
If you've got a LOT spare coin to spend, a 415, 427, or 440 stroker conversion would be the next obvious choice.
You're closer to Aaron, but Marc Haibec does them too:
http://zr1specialist.com/HAT%20Web/p...20upgrades.htm
While you have the tranny out it might be a good idea to send it to Bill Boudreau (The ZF Doc) and have it checked out and cryo treated.
http://www.zfdoc.com/index.htm
I highly recommend Bill's "C-Beam Plates":
http://www.zfdoc.com/c4beamplate.htm
Made a world of difference on my Z.
I used to be very wary of mashing the go pedal unless I was the only car on the road.
When the tires would spin, the rear end would step right. It felt like miles, but in reality probably only a foot or so.
The beam plates minimized it bunches.
Although torque still affects the attitude of the rear of the car it's no where near what it used to be.
I'm told that a rear end gear change is the best bang for the buck, 4:10's are usually what people put in.
It makes 6th gear usable on the freeway.
http://zr1specialist.com/HAT%20Web/products/gears.htm
Again, this is something Aaron can do for you, but it's always nice to see your options.
Good to see you again, and again,
Welcome to the.....
Brotherhood of the Beast!!!
TomC
a.k.a."Crabs"
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 09-01-2008   #4
Originally Posted by FLT4PWR
Hey guys,
thanks again.
Here is another article with information that might help you. I save the original article from the issue, but thanks to Corvette Fever ever better info is available online.
Old 09-01-2008   #5
Jeffvette
It's simple
1) Remove trans
2) Remove exhaust manifolds
3) Remove plenum and inj housings
4) Undo all wiring connections to the motor
5) Undo oil cooler and coolant lines
6) Remove power steering bolts (let unit dangle)
7) Remove ac compressor bolts (let unit dangle)
8) Lift motor
Some obvious steps skipped. Good luck!
Old 09-01-2008   #6
4DSZR1
4DSZR1's Avatar
Originally Posted by Jeffvette
It's simple
1) Remove trans
8) Lift motor
Most pictures I've seen of R & R engines in a C4 show the hood left in place. Jeff, whats your preference?
4DSZR1 is offline   Reply With Quote
Old 09-01-2008   #7
Polo-1
remove everything
Old 09-01-2008   #8
Contact Al Whittier
Yes it does cover the removal very well.
Old 01-05-2011   #9
Default Re: Engine and Transmission removal
Harbor Freight http://www.harborfreight.com/store-finder
2 Ton Foldable Hydraulic Engine Hoist........$189.99
1000 lb Capacity Engine Stand.................$49.99
800 lb Capacity Transmission Jack.............$129.99
2 ton Load Leveler (Ebay).......................$60
It was easy removing the transmission and engine from my 91' Z while it was positioned on KwikLift using these tools
Just had to add this Harbor Freight Hydraulic Scissors Cart.
1,000 lbs capacity. Minimum table height is 11 inches and maximum table height is 34.5 inches.
wow great breakdown of what's needed!!!!!
Old 01-05-2011   #10
I sell the CPT video and manuals for $45 shipped on CD......video shows removal process
leegaffigan@yahoo.com is paypal
http://www.zr1.net/forum/showthread.php?t=13558
