Old 08-12-2008   #1
robrtr
Smile Name that Screw!
I think the screw pictured below is called a 'rocker panel upper screw'. The pic is from my '92 ZR-1. Can anyone verify or, better, provide a part number, or, even better, let me know where I can pick some up. Thanks!
robrtr
robrtr is offline   Reply With Quote
Old 08-12-2008   #2
Default Re: Name that Screw!
robrtr
Email Polo-1 (Kevin) he had a bucket of bolts left over from his last car part out.
Old 08-12-2008   #3
Jeffvette
That is not a factory bolt. They never had marking like that. Plus you can see the outline of the original washer that is attached to the factory bolt. Supposed to be a 10mm head with a fine thread.
Old 08-12-2008   #4
robrtr
That's not good news, as the car was sold to me as an 'all-original' unmolested car. I just had it evaluated by a well-regarded corvette expert who appears on this site's list of recommended ZR-1 repair shops (he took the pic) and he concurred that it appeared to be correct, except for a replaced power antenna motor, which we knew about, and a possibly a replaced fuel filter. He noted that two screws were missing from the driver's side rocker panel.
Thanks for the posts.
robrtr
'92 #225
Black/Gray
Old 08-12-2008   #5
Jeffvette
Can you post a larger picture of the area. I should have some spares.
Old 08-12-2008   #6
robrtr
I'll check when I get home. No lift or floor jack (yet), so I'm not sure if I'll be successful. Off topic, but do you have any recommendations on a good jack?
Thanks.
robrtr
'92 #225
Black/Gray
Old 08-12-2008   #7
tccrab
tccrab's Avatar
Thanks.
You'll need the lowest profile jack that you can find. A standard floor jack will not fit under the front airdam.
http://www.sears.com/shc/s/p_10153_12605_00950167000P
TomC
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 08-12-2008   #8
robrtr
Below are more pics and a shot from the service manual. I probably named the screw incorrectly. There are six fasteners per panel. Screws #4 and #5 are identical to 1,2, and 3. #6 (front-most screw) is missing.
robrtr
'92 #225
Black/Gray
Old 08-12-2008   #9
Jeffvette
K, change of plan. Initially I thought you were in the wheel house looking for a bolt.
The screw is a 7mm head, course thread and about 3/4" in length. Currently not able to locate a part number.
I know Polo-1 has some of these as i removed the rockers. He'll just have to dig through a bucket of bolts.
Old 08-12-2008   #10
robrtr
Great! Thanks for all your help. I'll email Polo-1 directly.
robrtr
'92 #225
Black/Gray
