Old 08-08-2008   #1
ZWILD1
ZWILD1's Avatar
Default Why not ?
I have been looking at post in the CAC , LT4, LS1,ZR1 the C6 to C4's . If all these other engines are as good or better than the LT5 why doesn't GM go after the record that they set with the LT5 and regain it . They have the tools with the new ZR1 or do they just not care or just a bunch of tight wads.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 08-08-2008   #2
SC UL8R1990
Default Re: Why not ?
im not sure i understand your post, modular motors are alot more expensive than pushrod motors as far as production goes. GM wants to make money on the vettes.
SC UL8R1990 is offline   Reply With Quote
Old 08-08-2008   #3
Jeffvette
To much to lose, not enough to gain.
And no money.
Old 08-08-2008   #4
Kevin
Kevin's Avatar
he means going for the records
Old 08-08-2008   #5
SC UL8R1990
Oh sorry, misunderstood. Are we talking lemans records and such?
Old 08-08-2008   #6
Kevin
Kevin's Avatar
fiaa time/distance records that the ZR-1/l98 set when the car first came out
Old 08-08-2008   #7
SC UL8R1990
Gotcha, seems i need to dig back into my ZR-1 knowledge a bit.
Old 08-10-2008   #8
ZWILD1
ZWILD1's Avatar
That's what I ment the ZR1 was and is a very durable engine,or platform. Yes costly but durable. So if durability is not a problem then why not go for the record. I wouldn't buy a car that can't stay together no matter how fast. I would just build a car you tear down at the end of a season of racing. Isn't that why we bought a ZR1.
Old 08-11-2008   #9
rkreigh
a couple of simple reasons, the FIA is for bragging rights and really doesn't do that much for advertising. GM is in biz to make money. the high end stuff sells like crazy without a single dime spent on ads.
keep in mind EDS kicked in the $$ back when the original record was set, and there was an l98 car too.
GM did spend the big bucks on dyno and 24 hour testing at tracks like VIR
that was $$ better spent than the FIA which doesn't give the same eval data they were after dyno and track testing
the "ring" seems to be all the rage today, so GM spends their money there
don't underestimate the $$ needed to break the record, it's more than you might think,
