![]() Join Date: Nov 2007
I've drained 100% of the coolant to replace my water pump, and I seem to remember there was a procedure to eliminate air pockets in the engine (I seem to remember something about an air bleed valve(?) or something??). I wish had "cut and pasted" the article to my file at the time, but alas...
So, any "1,2,3..." help would be appreciated. TIA P. |
you can pull the rubber line that connects to the t body . just fill her up slow till you just get a dribble .then connect it back up and fill the over flow tank . start her and let her warm up all the way . shut her off and when she cools she will suck up the rest and you are good to go. might be different from some but its worked for me for 5 yrs . and easy for an old guy to remember
It was an article by Marc Haibeck in the HOTB newsletter #11, July '07. I don't want to post the contents as it is not my material to do that with. But if you are a registry member, just grab that newsletter off the site.
#4 | |
![]() ![]() P. Last edited by Paul Workman; 06-22-2008 at 04:02 PM. |
#5 | |
Paul,
I am about to replace my radiator and thermostat. I have worried over ![]() |
#7 | |
P. |
You can still buy silicated coolant from GM. Be prepared to pay through the nose now. The $18 per gallon that seemed so absurd before now seems like a dream. The last gallon I bought cost $30 from the local GM parts counter!
#9 |
So does that mean I need to buy the silicated formula from the General or is any formula that meets the "1825-M" spec good to go? Just call me paranoid but I want to get it right and not create any problems. Thanks.
#10 |
napa has 1825 spec its alot less than gm works fine
