Old 06-21-2008   #1
Default Car running like $hit.
Car started running like its only got 7 cylinders.Could one of the injectors finely has died or one of the coils has died?If one of the injectors died would it store a trouble code?
Old 06-21-2008   #2
Jeffvette
Default Re: Car running like $hit.
With the engine running, pull the spark plug boots off the plug. Listen for a change in the engine, and find out which cylinder is not firing. You should hear clicking noise of the coil firing as well. It'll get weaker the further you pull the plug boot out.
Old 06-21-2008   #3
I just checked the plugs wires,no problems here but the car is running right.Go figure.Hey Jeff,can I get that jack bag?
Old 06-21-2008   #4
Jeffvette
Definitely temp related then, look at injectors or coil. Check it when it's hot.
On the jack bag, yes. You still want that weatherstrip?
Old 06-21-2008   #5
When you say weatherstrip do you mean the fender skirt seals?If so yes,Ill take one side if its got the plugs in the ends.Now,will an ignition coil act up if it gets hot?I always thought when a coil goes it just goes.I was going to replace the coils when I did the injectors anyway.I had planned on working on my Nova tomorrow but maybe Ill get the Corvette up to temp and see if the problem comes back.
Old 06-21-2008   #6
Jeff, usually the hotter an injector and or an ignition coil gets, the worse the electrical issue becomes....it generally is the typical failure pattern.
Old 06-21-2008   #7
Electronics is my livelihood, and in my experience 'lectric stuff often times fails as a function of heating.
The coils on our LT5 are shared between two cylinders. So, if it is a coil failing, then two cylinders would be displaying the same problem, me thinks.
8-5, 1-6, 4-7, & 3-2
So, if it is one cylinder only, then I would put the coil at the rear of the line and look at plug wire, plug, injector, etc.
P.
Old 06-21-2008   #8
Ill replace the plugs.I was going to replace the injectors over the winter if they hold out that long.
Old 06-21-2008   #9
Nick
That's what I thought, too, until I had only one side of an Accel coil pack fail. The other 7 cylinders were running fine. Good luck.
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 06-21-2008   #10
Tyler Townsley
OK to check the coils/wires take a good plug and one at a time swap it for each cyl. Pull the wire, plug in the good plug lay it on the plenum and crank the car. Look at the spark across the plug gap the bad one shoud be evident and if the plug has good fire and it made it no difference you have a bad injector on that cyl.
Tyler
55 Polo White (Project)
61 Jewel Blue (Sold to buy above)
66 Nassau Blue
68 Torch Red
88 ZR1 Blue
90 ZR1 White
