Old 06-18-2005   #1
ZR1OUS 94
Default 94 0r 95 ?
Of these 2 Zs which one has better potential down the road as far as collectability and does the 10k miles more hurt the 95 as far as that goes??
1..94 ad. blue/gray 4.5 k miles both tops, Borla exhaust,chip...
2) 95 blk/blk 14.5k both tops,chip,new tires ,battery,1k more in price than the 94.
BOTH cars look in exc. cond from the pics I received,both are original owners..
Do you think the 94 is a better buy because of 10k less mileage? or the 95 because of last yr made and new rubber which will probably cost at least 1,200.00 correct? for the 94..I dont plan to sock either car away but either will be used very little and showed when I can....Thanks for any help!! i have to make a decision today or tomorow......
ZR1OUS 94 is offline   Reply With Quote
Old 06-18-2005   #2
Z Factor
Z Factor's Avatar
Default
I don't think you can go wrong either way. You have not mentioned a price or even a range the sellers are asking?
The 94 has fewer miles and has a color that is not common, so I'd think it would be more sought after, but many years from now, not the near future. However, it depends on not only which car is in better condition, but also which one you like better. Since you are not going to store it, you need to be happy with it day in and day out.
Good luck
