Old 06-13-2008   #1
jonszr1
jonszr1's Avatar
Default injector housings any problems changing between years ?
i want to put a set of ported injector housings off a 90 to my 92 . can this be done without any problems. i know about the diff in vacume lines which is no bigge. but i thought i heard there was a little difference in the 90 from the others ? anyone know ? thax for your help in advance
Old 06-13-2008   #2
Default Re: injector housings any problems changing between years ?
as far as I know 90-92 IH are the same.. just like 93-95 IH are the same
Old 06-13-2008   #3
jonszr1
jonszr1's Avatar
phew thanx for the help jeff.
Old 06-13-2008   #4
Aurora40
Aurora40's Avatar
The '90 plenum is unique, but I *think* the injector housings are the same from '90 to '92.
Old 06-13-2008   #5
WVZR-1
Actually I believe '90 and early '91 MY IH are similar and the later '91 and the '92 MY are the same. Then of couse the '93 + MY's. Can you swap early and late '90 & '91 MY parts I really DON'T know!
