Old 06-08-2008   #1
Default Kurt White Short throw shifter
How does Kurt's short throw shifter kit compare to others with regard to performance, and install. I see you keep the stock shifter, and its a linkage change.
92 ZR1
#234
Old 06-08-2008   #2
Default Re: Kurt White Short throw shifter
92 ZR1
#234
I dont know but im happy with Bill B' kit from Cavecreek......
Old 06-08-2008   #3
bobbyhi
bobbyhi's Avatar
92 ZR1
#234
I took Kurt's shifter off and replace it with a Hurst. I didn't like the "throw" on Kurt's. Missed 3rd too many times. IMHO only.....
Bob Anderson
1990 #2405 White/Gray
Haibeck chip,4:09 gears,Power Effects Exhaust,5 spoke chrome,C5 brakes,49th Street rockers,K&N,Hurst,Headers,Upper & lower ported
Minnesota State Director
Founding Member #19
Old 06-08-2008   #4
Ive heard that before on 3rd so its not just you.
Old 06-08-2008   #5
92 ZR1
#234
Let's see.. I had a KW Shifter, heck I probably can find all the parts if you really want it.. I bought it because that was all that was avail. at the time (1999-2000).. The B&M followed then the Hurst.
For the KW, you need to Mod the trans housing, also it lowers the rod attaching point so you could rip the boot over time and I found it to be very notchy and sometimes harder to shift. it did shorten the throw over stock though.
I have a Hurst in my 89 and my 90, should have been OEM or atleast an option.. I never used the B&M but I think the Hurst fits well, you could also mod a stock shifter if you want I think I have 3 or 4 Stock shifters around here..
IMHO, I would do the Hurst or if you want the retained Reverse Lock Out Ring then a Bill B. Modded Stock one..
Old 06-08-2008   #6
bradslt5
bill brooudreau just a month ago bluprinted my trans and modded my hurst shifter. it now is spring loaded so there is really no way to miss 3rd gear at the strip .if you want the best you can find get one from bill .you will be glad you did
Old 06-08-2008   #7
Whats a Bill B shifter run?
92 ZR1
#234
Old 06-08-2008   #8
92 ZR1
#234
This is the price I got from him last July..
Originally Posted by Bill Boudreau
Unless your get into a ’93 C4 or older where they have a reverse lock-out lift-ring type shifter, the Hurst shifter will be your best bet. A modified lift-ring shifter would be $185 plus your original shifter as a core.
The modded stock shifter (No Lift Ring) is now $155 and takes a few weeks to make based on my welders schedule.
Production time is the same on the lift-ring modded shifter as well.
I’ve seen the Hurst shifter going for $135 from Summit.
Old 06-08-2008   #9
I just got a Hurst and LOVE IT...... Never tried B / M, but heard great things. Don't know Kurts shifter either
Old 06-09-2008   #10
bradslt5
the hurst isnt a bad shifter if you dont want to wait for bills. i wouldnt get a b&m i have hears they arent very good at all.jmho
