06-02-2008 | #1 |
Video Post of Dyno Run
Thanks to Bob Stencel for the videos and great pics:
http://s134.photobucket.com/albums/q...noJetPulls.flv LGAFF 92 ZR1 #234 |
06-02-2008 | #2 |
Re: Video Post of Dyno Run
Awesome, Lee!!
06-02-2008 | #3 |
Nice run
What did the barbie car dyno at ?
06-02-2008 | #4 |
Barbie vette dyno'd at 392rwhp......power to weight ratio is incredible.
LGAFF 92 ZR1 #234 |
06-03-2008 | #5 | |
Power key was on!!!!!!!!!!!!!!
06-05-2008 | #6 |
Just talked to Randy at DRM, asked him about lean condition(I have a DRM chip), said no way it should do that even with my mods. Might be injector issues, I noted in another post I used SAP for my primaries, could have gone bad in a year I suppose.
LGAFF 92 ZR1 #234 Last edited by LGAFF; 06-05-2008 at 01:45 PM. |
06-05-2008 | #7 | |
Most tuners set their cals up to be on the rich side. Mine is a Marc Randolph cal and the initial pull on my motor with that calibration was in the mid 13s AFR. They'd rather foul plugs than blow pistons. 390rwhp is pretty healthy number to have an "issue". I would look at FP at WOT. Bottom line is putting scantool on it and see if it shows anything. You did mention that you had smelled gas in the garage. |
06-05-2008 | #8 | |
No you are correct, raw gas smell from the plenum when I cracked the TB open. LGAFF 92 ZR1 #234 |
06-06-2008 | #9 |
you used a wideband o2 right? the Dyno owners Wideband? how do you know it is accurate? might not be. I would suggest if you are going to tune yourself, the Wideband will be a good investment.
otherwise, i think the problem is the loose nut behind the wheel
06-06-2008 | #10 |
Cool video......car looks mean on the dyno!!!
[IMG]http://i43.photobucket.com/albums/e396/ry368/Zr1launch/Goodfellas-1.gif[/IMG] Here, let me help you with your Vette...lol! [B]1991 QuAsAr BlUe Zr1 w/415 1967 Nova w/Sb2 power!!! 1991 GMC Syclone [/B][FONT=Century Gothic][COLOR=blue] [/COLOR][/FONT] |
