Old 05-29-2008   #1
SC UL8R1990
Default " SYS " flashing next to fuel bars / mpg
What causes the digitial display to flash the letters SYS where it normally shows MPG? I noticed this morning it would flash " SYS " then go back to showing my MPG. It did this my entire drive.
any and all help is much appreciated.
SC UL8R1990 is offline   Reply With Quote
Old 05-29-2008   #2
SC UL8R1990
Default Re: " SYS " flashing next to fuel bars / mpg
*UPDATE*, did a quick search and found someone with the same problem. I replaced my battery last night, i'm guessing the sys light will go out on its own .
Old 05-29-2008   #3
gbrtng
gbrtng's Avatar
Probably a blown fuse in a body circuit somewhere. Pop the cover on the RH side of the dashboard and check them. If all are OK, get a code reader and a service manual for the next step ...
Old 05-29-2008   #4
zrss
Sounds to me like your positive battery cable is not tight. I had the same problem from a loose cable. Removing and reconnecting the cable (tightly) at the battery will probably solve this one.
zrss is offline   Reply With Quote
Old 05-30-2008   #5
RHanselman
RHanselman's Avatar
This happens to me every time the battery gets low on its charge...
Ron Hanselman
Founding Member #80
CM Lifetime Member #1093
1991 #383 Twin Turbo
1993 #099 Ruby, Jeal 368 w/Snake Skinner body
1961 White with Red Int
RHanselman is offline   Reply With Quote
Old 05-30-2008   #6
SC UL8R1990
light was out on my way home. i suppose it was due to changing the battery, all is well.
thanks all
