Old 05-04-2008   #1
Default Serious Problem with car
Took the car out for a brief sprint down the road, however I noticed a serious problem. When I get on the gas even while the car is moving, with ASR on, I don't really go anywhere the tires just spin, and the car kicks sideways.
I don't have any type of scan tools, but my diagnosis is that I have way too much power
Some problems are good problems to have
I did have a high idle when I first started, however I shut the car off and restarted and it dropped to 750, and was fine after that.
I do have one question, how much should the serp. belt tensioner bob up down. Mine bobs more than a truck stop call girl.....wondering if I need to replace.
92 ZR1
#234
Old 05-04-2008   #2
Default Yeah...Typical problem w/ these cars...
Try putting a block of wood under the accelerator, or turn that switch on the dash to the left. That MIGHT help
As far as kicking out to the right, I'm hoping some of Bill B's beam plates will cure that.
Well, I've got to go out and install that block of wood...Too danged nice out to let the Z sit!!
P.
Old 05-04-2008   #3
Aurora40
Aurora40's Avatar
Default Re: Serious Problem with car
For the tensioner, here's mine:
http://vettetube.com/view_video.php?...663b8d9fb4be56
People seemed to think that was normal.
Bob Saveland
Former owner of #2517
Old 05-04-2008   #4
Mines about the same, maybe thats needed for the high rpm.....too tight maybe the stress would damage the belt.
92 ZR1
#234
Old 05-04-2008   #5
Kevin
Kevin's Avatar
loose cbeam bolts?
Old 05-04-2008   #6
GrayZ
I've ran across the same problem with putting pressure
on the accelertor, my car smells of burnt rubber and
the engine seems to increase in volume.
High idle could point to a vaccum leak? I had one, and thats what she did.
I believe the belt is designed to flex. but i've been wrong before.
GrayZ is offline   Reply With Quote
Old 05-05-2008   #7
Ya got to get the tires up to temp before ya start to play with those high hp Z's
was the battery disconn'ed? It may have had to relearn "cold start" for the IAC? Usually that happens to mine everytime I have the Batt disconn'ed for work.
My tensioner bobs quite a bit @ idle also.
Old 05-05-2008   #8
32valvZ
32valvZ's Avatar
I have the same problem!! I was in town earlier and it seems the mechanic cant get it fixed either.........the whole car was just fishtailing and white smoke was coming from the tires as he made his turn onto the highway!! Frikken ZR-1's man
[B]1990 #2815[/B]
Ported Plenum & IH (by Pete)
Haibeck Chip
Rebuilt FPR (by Phil)
FIC Injectors
Watson LT Headers
3" Stainless Works exhaust
Lingenfelter Open Air Lid
Bill B Built Transmission
Shifter & C Beam Plates
[B]SOLD[/B]
