![]() Join Date: Dec 2003
I'm going to be in BG for the C4/ZR-1 Gathering.
I will also bring gaskets, seals, water pumps if you want to pick it up there. Let me know what you want beforehand & I'll be sure to have it there. BG hand delivered specials, no minimums : #17112267 Gasket Set, Throttle Body reg $ 49.99, BG Special $ 42.00 #10168684 Gasket Set, Plenum reg $ 23.50, BG Special $ 20.00 #10135833 Water Pump, OEM w/gskt reg $341.00, BG Special $320.00 I won't bring everything, so if you need something, let me know so I bring enough stuff. ![]()
Jerry Downey JERRYS LT5 GASKETS & PARTS http://www.jerrysgaskets.com 1994 ZR-1, Black/Black, Lingenfelter Aerobody, 416cu in, 3.91 gears, coil-over susp, Brembo brakes, etc. 2016 Black-Red, 3LT-Z51 Auto 8-speed. Last edited by A26B; 02-27-2011 at 03:51 PM. |
