Can someone remind me how to switch the ACC display so it reads engine coolant temp instead of ambient air.... I can't find a link anywhere on how to do it and I know it's just pushing the buttons in a certain sequence.
![]() Thanks Hans |
![]() Join Date: Mar 2004
Press and hold both fan up and down arrows for about 5 seconds (until “00†) appears in the display. Use either fan up or down to scroll to “16†then press fan “autoâ€. Coolant temp will then be displayed in degrees C.
Thanks!!!
![]() Hans ![]() |
![]() Join Date: May 2007
That's pretty cool. Is there a write up somewhere of all the parameters that can be displayed?
Jim |
#5 | |
I second that. Had no idea this was possible. On a 90? or 91?
It's in the manual
00 - System faults 01 - Temp setting in degrees 02 - In car temp sensor 03 - outside ambient air temp 04 - Sun load sensor 05 - Ignition system voltage 06 - Engine speed /25 07 - Vehicle speed 09 - System mode 10 - Blower pulse width modulation 11 - Program number 12 - Mix number 16 - Engine coolant temp Cent 30 - Stored full hot value 31 - Temp door travel range 34 - Temp door feedback 35 - Compressor on time (in seconds) 36 - Number of times below critical time 37 - Software version number |
Thanks Jeff.
#8 | |
Must of missed that page? Thanks Jeff
#9 |
Outstanding! Thanks.
