Old 04-07-2008   #1
Default Coolant Tube cracking
OK. Here's one of the coolant tbe with a fracture at the bolt boss. Fracture is thru material. Can I weld it back up?
Old 04-07-2008   #2
Jeffvette
Default Re: Coolant Tube cracking
Yea, you can weld it up and then grind it smooth again. Should not be to difficult.
Old 04-07-2008   #3
Jeff,
What causes that? Was bolt just overtorqued? BTW, ordered bolts from McMaster.
Old 04-07-2008   #4
After welding, you need to make sure its not warped on the mating gasket surface.
A26B is online now   Reply With Quote
Old 04-07-2008   #5
Thanks. I'll make sure to check that once its fixed.
Old 04-08-2008   #6
Originally Posted by XfireZ51
Jeff,
Man Dom somebody really overtourqued that coolant pipe IMHO
Old 04-08-2008   #7
That was my first reaction.
