Old 03-24-2008   #1
Default Secondary Port Throttle Parts
Posted this on the "other" site.
I took apart secondary port throttle assembly as part of preparing to do port matching on DIY Top End project. When I removed lever mechanism on passenger side, I had 4 "tab washers" which position the lever with the throttle plate shaft. However, when I removed the driver's side, none of the levers had any tab washers with them. So the possibility exists that although the secondaries may have opened, each cylinder may have opened just a little bit differently than the other. Or everything worked just fine. Anyone have any of these tab washers available? You can email or pm me and let me know.
Are they necessary?
Old 03-24-2008   #2
Polo-1
Default Re: Secondary Port Throttle Parts
Kurt has them.
$24.83 each
http://www.whiteracingproducts.com/i...ex&cPath=10_72
If you cant find any, I think I have some.
Old 03-25-2008   #3
$24.83 each
Damn....My A** hurts just readin that.
92 ZR1
#234
Old 03-25-2008   #4
How many can you possibly sell? He keeps trying to hit a home run and causes people to look somewhere else instead of becoming a source.
Oh well. Just some free marketing advice.
Old 03-25-2008   #5
Originally Posted by LGAFF
$24.83 each
92 ZR1
#234
Dont forget the shipping add on too. Your azz will hurt a little more.
Old 03-25-2008   #6
You know there's probably some guy in Stillwater, OK named Bubba that has all of these parts in his garage or a rusted out storage shed in the back yard, next to an assortment of old lawnmowers, lawn jarts, and a croquet set.
92 ZR1
#234
Old 03-25-2008   #7
92 ZR1
#234
Right next to that assortment is Jimmy Hoffa
Old 03-25-2008   #8
92 ZR1
#234
Little does he know that according to White Racing he is sitting on something more valuable than gold.
Old 03-26-2008   #9
bradslt5
thankfully there is more than one way to skin an englishman i mean cat no offence intended jus tcouldnt helpmyself
Old 03-28-2008   #10
Just wanted to thank everyone for reaching out to help on getting these parts. Brad Taylor sent me his secondary assembly so I'll be able to move ahead on getting this thing put back together. Thanks also to Polo-1.
Let me know if I can return the favor.
