Old 01-28-2008   #1
Lowflight
Lowflight's Avatar
Default Performance Questions About Gears and Exhaust
Gears:
Will 410 gears drop my Quarter Mile Time?
Do you have to retune the chip to correct the Speedo?
Do they make 6th gear more like 5th?
What is the top speed reduced to?
Exhaust:
Headers will make my B&B Exhaust (old style Mufflers with latest gen Resonator) Intolerable won't they?
Lowflight is offline   Reply With Quote
Old 01-28-2008   #2
bradslt5
Default Re: Performance Questions About Gears and Exhaust
on if they drop your times i am not sure . it gets tougher to get traction plus the extra shift . i personally am going to try 3.73 and 410s at the next 2 day test and tune in my area . i mght also try the 3.45s if time allows . on the street 410s make 6th gear cool . 72 mph is 2000rpms and passing you just click to 5th a off ya go . have noticed that fuel milage has gone down 2-4 mpg but that might be a right foot problem . if you go to 410s you have to by the plastic gaers that go into the trans to keep the speedo right . they arent cheep about 120 from mark . if you go with 3.73s that price goes to 20-30 from gm. i am kinda thinking that 3.73s might be the best overall gears. easier to get traction at the strip and just the perfect cruizing rpms for gas and no lugging . but that is just my opinion .petes fully ported 350 has gone in the 11.30s with 3.45s
Old 01-28-2008   #3
Lowflight
Lowflight's Avatar
Also, would these lower gears keep the RPMs up more when driving and actually reduce the resonance of the exhaust? As it sits, I can't drive in 6th without every part made of plastic in the car vibrating....
Old 01-28-2008   #4
Nick
Originally Posted by Lowflight
Gears: Will 410 gears drop my Quarter Mile Time?
Maybe. I hope so, as I just went to 4.09's.
No. You have to a) change the transmission speedo drive and driven gears, or b) add an electronic speedo correction box.
Yeah, that's kinda the description I'd give. I am much more apt to use 6th gear on 70 mph (or under) freeway speeds now that I was with stock gears.
Dunno; haven't gotten that far in the research yet.
Exhaust: Headers will make my B&B Exhaust (old style Mufflers with latest gen Resonator) Intolerable won't they?
Well, how well do you hear now? If not very well, it won't matter. If pretty well, you won't be able to hear very well soon enough if you go with that combo!.
Nick
ZR-1 Net Registry Founding Member #32 - lapsed...
Old 01-28-2008   #5
bradslt5
on the exhaust all depends on where the reasonance is . i got totally rid of it by going to that x pipe reasonator that dyno max makes .its 3in inside weather you have 21/2 or 3in in and out pipes. now its quiet without powerloss. borla recently came out with their exhaust for the c-6zo6 that is using an xpipe reasonator .hope this helps
Old 01-28-2008   #6
Aurora40
Aurora40's Avatar
I've heard about .2 or so reduction in the 1/4 mile factoring for the extra shift.
5th gear is .75 and 6th is .5. So to really make 6th like 5th, you would need a 5.18:1 rear end. But it's somewhere in the middle. Top speed becomes limited by RPM. 7,200 rpm gives you something around 173-175mph I believe in 5th gear.
Bob Saveland
Former owner of #2517
Old 01-28-2008   #7
Lowflight
Lowflight's Avatar
Though more expensive, porting the heads would give me more power in the 1/4 mile.
Old 01-28-2008   #8
Aurora40
Aurora40's Avatar
I think so. At BG, I was paying attention to Keith's car. He has headers, cat-back, and 4.10:s. I have headers, cat-back, and porting (both are '90s). I believe he was running in the 12.7-12.8 range? I was running in the 12.5-12.6 range. Perhaps he'll weigh in to clarify his times though.
Bob Saveland
Old 01-28-2008   #9
Lowflight
Lowflight's Avatar
With regard to exhaust, I am trying to work around my B&B. I have the early mufflers and later resonator...so my system is probably 12% louder than a brand new set in terms of resonance and general sound. If I added headers, I would probably go crazy. I prefer the look of the B&B tips and don't want to go to Corsa in terms of looks cost of switching and all around hassle.
So, I want to do as many mods as possible without adding headers right now.
Old 01-28-2008   #10
Hammer
Hammer's Avatar
Talking Re: Performance Questions About Gears and Exhaust
From what I can tell, looking at all the times on the Registry, with 3:45 gears, your best 60' times are going to be around a 1.95. All the Z's running 1.6's to 1.8's (modded or not) were running 4:10's. I think this would be where you pick up your E.T.'s.
