Old 01-14-2005   #1
MIZR1
MIZR1's Avatar
Default Disabling LTPWS indicator
I have my DIC out (wait, that doesn't sound quite right) and want to disable the LTPWS indicator. I read here that I may simply remove the bulb. My question is: there are 2 bulbs; do I remove both, or only one? If only one, is it the left bulb or right, as you face the DIC? Also, will the other warning indicators continue to work if one or both of these bulbs are removed? Finally, I dropped a screw while removing my radio. Can anyone tell me where it is? :-)
Thanks in advance for your help.
MIZR1 is offline   Reply With Quote
Old 01-17-2005   #2
Mikez40
Default
I put 18" wheels on my ZR-1 and had to remove mine. I believe it is the right side that you remove...There will be no effect to other warnings indicators.
Mikez40 is offline   Reply With Quote
Old 01-18-2005   #3
MIZR1
MIZR1's Avatar
Default
Thanks for responding, Mike
