I did a few upgrades to the brakes and want to share a few pics...
Pretty much the typical OEM look when I started... my project included rust removal from hubs and upgrading pads and rotors.. ![]() I have kept the OEM rotors, but will be sending to a company in California to bead blast and zinc coat (thus can return car to OEM set up)... here is their work on my C6 Z51 brakes>> Before ![]() After ![]() For purposes of removing rust from hubs and leaving a zinc phosphate coating I use a product from EastWood... OxySolve which they now call Fast Etch and steel wool/brass wire brushes (really only need for stubborn spots)>> Here is the ZR-1 hub after treatment ![]() And now the completed set up.. EBC sport rotors, EBC ceramic pads, Goodridge SS lines and new caliper hardware ![]() Note: black on rotor to pad contact area will rub off when brakes are used...this pic was prior to brake usage. ![]() Michael Last edited by ZR1Vette; 01-19-2008 at 09:27 AM. |
And here are the rears>>
Before ![]() After ![]() |
![]() Join Date: Nov 2006
Michael. Looks awesome. You are making good progress on your upgrades. I think I will be purchasing a lift by the way. I thought yours was really cool. Have to try and get my suspension looking as clean as yours!
Cheers, Keith '90 Red/Red #1383 |
![]() Join Date: Jan 2004
I saw michael's car first hand and it's spectacular!! nice to see another pristine ZR-1 in VA. thanks again for hosting the get together, it was alot of fun.
enjoy your ZR-1, it's a beauty! I need to do the same to detail the suspension and really appreciate the pics and tips. what did you use to clean off the a arms?? |
![]() Join Date: Apr 2004
Michael,
Would you mind providing contact information for the shop in California you used to plate your Z51 rotors? How did you package the rotors for shipment? Thanks, Scott |
![]() Join Date: Jul 2005
Damn, looking good!
![]() Join Date: Jul 2007
looking good..
Hey it looks like you even have Steel half shafts on that one.. I think my 90 has aluminum, but I never really looked to close
Ron... arms etc were in good shape but I used Brake Kleen & Parts Cleaner (non chlorinated) on a rag to really bring them up to clean...
Scott... sure... company is called Specilialized Processing in El Cajon CA 619.442-0663 I sent them via FedEx ground in two boxes (each with two rotors)... wasn't bad cost wise. Specialized Processing will charge about $125 for all four rotors (they did about 2 years ago anyway) Jeff... yep to steel half shafts... my VIN is 1990 #566 and I found out that they transitioned over to aluminum at about VIN #620 or so... any advantage or disadvantage of steel over aluminum or vice versa? other than the obvious weight difference ![]() Now off to all fluid changes.. Thanks all Michael |
#9 |
The steel is stronger, and of course heavier. I think they weren't sure the aluminum half-shafts would take the power? I think the only disadvantage is the weight, and possibly the appearance since they always look rusty.
#10 |
What type of lift is that? Is it a permanent in-floor lift, or one you can move around the shop?
