![]() Join Date: Nov 2007
Ok, I got the cojones & did it. What should I look for or test while its off? How do I tell which injectors I have? I tore the gasket on the throttle body to plenum, can I get a new one? Can I re-use the plenum to intake port gaskets? I see some oil on the plenum floor & on the throttle body & blades...is this very bad? I got some coolant in one or 2 of the intake ports.....now what?
Theres mere to come I'm sure......Hey you guys gave me the confidence to do this, now dont be mad if I'm a pain in the ***!! ![]() |
#2 | |
![]() Join Date: Oct 2004
you could do the drain mod...redrill the hole to allow proper drainage of the valley. you could inspect the starter. you should replace the breather box gasket and loctite the bolts on that.(that is likely where the oil is coming from) you should have purchased some gaskets prior to starting. what color are the injectors? do they have any writing on them? you can reuse the gaskets if they are OK. you could buy some new Samco breather Box hoses from Kurt White (expensive) the oil in the throttle body and blades is common...esp if its a 90. no valve seals. the coolant in the intake ports is nothing to worry about if it's not a lot. why did you pull the plenum in the first place? |
I pulled the plenum in hopes of finding something that pointed to my off idle miss or vibration problem. I dont see anything obvious.....I wish I did. Where is the hole I need to drill? Is the breather box the thing with 2 big hoses on it? Injectors are black with pt #'s on the tops.
#4 | |
The Drain Hole. - Look over here. http://www.bcvettes.org/ look at the How To Section. It is the one for the starter motor...has great pics so you don't have to be nervous about where to drill the hole. BTW...the coil packs will have to be removed as well..and that's also in their HOW TO section. Breather Box - yup the one with the two big hoses. typically the bolts are loose and oil is leaking from the box where the upper half bolts to the lower half. Injectors - Black with steel bottoms - most likely they are Multec (original equipment). replacing injectors is ALWAYS a good idea if you have the early style Multec injectors. The new fuels (with lots of ethanol) are hell on these injectors...and it significantly shortens their life. I would recommend replacing them if you can afford it. Accels (P.N. 150121) are about the cheapest way to go for ~$550 a set of 16 and the RCs are about twice that price. One more thing...do you have a Factory Service Manual? If not...get one here. http://tinyurl.com/ysrbpn |
![]() Join Date: Dec 2003
Get mad phooey
Some of us love this sh!t You didn't have to pull the TB we forgive you this time,since it's your first time,damn virgins J/K ![]() If Plenum gaskets look ok reuse. Oil in the plenum is common just sit it up right for it to drain or spray some brake cleaner into it but make sure the hoses and MAP sensor are off. Water in the intakes/cylinder for safety pull all the plugs and crank the motor. Check injectors (Ohm check) with a voltmeter inexpansive one from Radio Shack Check your wires just in case they are chewed up from mice (common) i would replace them for $50 since plenum is already off. If you don't feel confident on drilling a hole take an air hose and blow out the drain hole (under coil packs and starter have to be removed make sure battery is disconnected before taking starter out) You can also check coils.(do a search or check manual) Also check/do what Guinnessdood suggested If you see oil residue around the breather box (yes with the 2 big hoses) do what guinnessdood said. Vacuum pump can be bought at Sears for around $60 If you need a TB gasket i might have on laying around $15 Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 01-17-2008 at 04:23 PM. |
Pull the plug wires off of the coil packs. Inspect for orrosion or arcing. Clean like a mad man. Check the vacuum pull on the secondary actuators. Should be fully open ad 8 inches of vacuum. Should be a smooth transition.
Also check here for some images. http://www.pnwzr1.net/PNWZR1.htm |
Just in case.
How to check secondary actuators with the vacuum pump. pull the vacuum hoses off the actuators install the vacuum pump hose and pump the pump they should be wide open where Jeffvette mentions. Pete
...continuation of the above...the opening of the plates should be smooth (I guess Jeff already said that)...no binding and they should be fully open at 8 inches of vacuum. Each side can be checked independently.
#9 |
Ok, heres what I know from the previous owner. The plug wires were replaced in May (ish) 07 They look really good. Also, a few weeks ago, I checked the injectors with an ohm meter while hot. They all specd out between 13.7 & 14.0 ohms.......should I replace them anyway? The 2 hoses on the breather box are really hard...does that mean replacement?
#10 | |
My breather box hoses were hard too...but they still work. Kurt White has some of the original hoses and some Samco hoses for the breather box. The hoses cost at least $45 each....which to me is ridiculous. You may be able to take the hoses off and go match them up to some that will work at a parts store. |
