01-01-2008 | #1 |
Just a couple pics of my 92
this was when my son was home from the USMC for thanksgiving.....we rode in the Z06 & my wife drove the ZR1 been doing some cleaning up under the hood |
01-01-2008 | #2 |
Re: Just a couple pics of my 92
Looks good... what do you use for cleaning the engine? I'd like to get started on mine, but have read that the plenum is easy to stain.
01-01-2008 | #3 | |
Ry from thornton,co.........Hello |
01-01-2008 | #4 |
lookin' good. a couple of cool shot's .
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
01-01-2008 | #5 | |
The genius tried the same thing in all the wheel wells with black, so I had to use acetone to remove all that. It worked excellent & without damage to the liners. I have read that a weak solution of Simlpe Green & water works. |
01-02-2008 | #6 | |
I have already checked the injectors and all the obvious things w/o luck so far. I'm not sure if its fuel or ignition related just yet. The car runs excellent otherwise....so I just dont know yet. If I have to pull the plenum, believe me, I will give it a thorough cleaning. A few guys have given me some good pointers and advice so far...but the T1 seems like a must have, so I'm waiting for that. I hope to see you sometime at a show,cruise or event or something. Last edited by 32valvZ; 01-02-2008 at 08:55 AM. |
01-02-2008 | #7 |
Looking good
01-02-2008 | #8 |
Nice 92! Glad to hear you spent some time with your son over Thanksgiving. I appreciated this years Thanksgiving a lot more as last year I was in AL-Qayarrah Iraq on a 14 month tour.
Cleaning the ZR-1 is a bear and staining is a problem. If you do decide to pull the plenum and clean out the galley and service the coil packs and such you might consider having Jeffvette Powdercoat the entire top end like I did. Clean up is a breeze. Results well judge for yourself. GC! Last edited by GOLDCYLON; 01-02-2008 at 12:31 AM. |
01-02-2008 | #9 |
lookin Good
01-02-2008 | #10 | |
On a side note, I have noticed an assortment of different color tones on these engines. Some are a darker grey like mine, & some much lighter like yours and a few are in between the two.....should they all be the color you have? |
