Old 11-11-2007   #1
bradslt5
Default head gasket cam timing tools?
what tool /etc are needed to change the head gaskets and set the cam timing? where can they be purchased/ thankyou for any help you can provide
Old 11-12-2007   #2
Pete
Pete's Avatar
Default Re: head gasket cam timing tools?
The cheaper way.
A few Metric sockets from Sears,Torx,Torque wrench,Breaker bar.
Cam timing you can use 15/64 drill bits, i will have to double check the size.
Are you doing this with motor in the car?
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 11-12-2007   #3
bradslt5
no , from what I understand (i am a new owner) its alot better to do this with the engine out of the car. also is porting of the heads worth the money? if so who does the best work? thankyou again for any help
Old 11-12-2007   #4
tccrab
tccrab's Avatar
Porting/polishing/powerdcoating = Jeffvette + LocoBob.
http://www.pnwzr1.com
'Nuff said.
T
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 11-12-2007   #5
lbszr
lbszr's Avatar
Camshaft temporary retainers was the only tool I bought from kent moore which was expensive and they are plastic, the other supplier I couldn't contact at the time but I hear they are aluminum, which might work better, I broke one of the plastic ones. There all here. http://www.zr1netregistry.com/ZR1_parts.htm temporary chain tensioners aren't too hard to make. Piston stop can be made if you do the degree wheel method. Mark Haibeck has camshaft bolts that need replaced and online info on resetting the chain tensioners.
[FONT=Comic Sans MS][COLOR=red]"I wanna go fast!!"[/COLOR][/FONT]
[FONT=Comic Sans MS][COLOR=#ff0000]-- Ricky Bobby[/COLOR][/FONT]
Old 11-12-2007   #6
bradslt5
thankyou for all the help. I will get ahold of mark haibeck. in reading around he sees to have a great rep. this is kind of a scary job . i have done alot on standard small blk dhev. mut this is way different. too bad there isnt someone closer that i could take the car too just cant afford the shipping of the car. i could ship to so cal through a friendif there was a shop there that does this . anyone know if a place in so cal?
