Old 11-10-2007   #1
kenthompson
kenthompson's Avatar
Default Clutch time redo
Well,
It turns out that the noise was the pilot bearing turning inside the crankshaft. The clutch was fine, the throwout bearing was fine.
I could have put a new pilot bearing in and been done two weeks ago.
Course, I had to put the Fidenza in.....
Now, the pressure plate that I bought (Valeo) was about .200" thinner than the original. I thought that was curious, but maybe it was right.
Then, when I went to put it back together, the transmission didn't want to go in. After MUCH consternation and cussing, I figured out the new throwout bearing had a plastic bushing inside that was preventing the transmission from homing. Put in the old throwout bearing, and away it went.
I read somewhere that the nose cose on the transmission is larger on the ZR1 Transmission than the regular C4.
Does this mean I've got a clutch for a regular C4?
kenthompson is offline   Reply With Quote
