Old 08-07-2007   #1
janozr1
Default zr1 SECONDARY PORT VACUUM ACTUARY
Anybody want sell to me or tell me where can buy part #1996743 ???
thanks,Jano
janozr1 is offline   Reply With Quote
Old 08-07-2007   #2
Jeffvette
Default Re: zr1 SECONDARY PORT VACUUM ACTUARY
GM should still have them. But the failure rate on brand new ones is roughly 75%. I typically will order a dozen at a time.
Old 08-07-2007   #3
janozr1
yes , it is true I chaned them 12kmiles ago , and both are now with holes , they are made in mexico i think so I didnt want to belive ----AGAIN same mistake under plenum , but it is also true that Im running with haibeck chip all the time on 400hp....
Kurt save me again =D>
Jano
Old 08-08-2007   #4
Pete
Pete's Avatar
Just take the complete secondary system off and you won't have to worry about finding or buying expensive parts.
Problem solved.
And you will pick up about 6-8 horsepower with no driveability issues.
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 08-08-2007   #5
kenthompson
kenthompson's Avatar
Without pulling the throttle blades, what do you do? Wire the blades open?
kenthompson is offline   Reply With Quote
Old 08-09-2007   #6
janozr1
just blades open and disconetting vaccum ? What will ECM say ?
Old 08-09-2007   #7
Pete
Pete's Avatar
Take the blades out,take the shafts out,plug the holes with freeze plugs,
send chip to Marc H. to eliminate secondaries or run the vacuum pump hose to the one side of the secondary solenoid closed side then run the open side of the secondary solenoid to the differential MAP sensor under the ECM,no codes and no more headaches,even with the above mentioned you will still need to send the chip to Marc H. to reprogrm it for the secondary key to always stay ON among other things.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
