07-18-2007 | #1 |
oil leak
finely found it! had leak right front of engine leaking on frame and going everyware.after checking oil pan',the lower timing cover bolts were loose but not the leak.lower right front of engine it's called oil pump access cover bolts were loose.tighten bolts leak gone.gm manual supplement page 6a2a-6 #423 is the cover.it's a real bear getting to but you can from the top. hope it helps.
07-19-2007 | #2 |
Re: oil leak
Any thread/post that informs fellow ZR-1 owners is always helpful.
07-21-2007 | #3 |
Re: oil leak
Second time I've heard of this leak. Thanks for posting a problem solution. Too often, all we get to hear about is the problem and the recommended fixes only.
Jerry
07-21-2007 | #4 | |
Re: oil leak
I looked up page 6a2a-6 #423 and couldn't determine exactly where this cover plate is located on the engine. Can you please provide a few more details or maybe even a photo? Thanks for sharing this with the group. |
07-21-2007 | #5 | |
Re: oil leak
Dan |
07-21-2007 | #6 | |
Re: oil leak
I'm with Dan, do you have to remove anything to get to it? thanks! |
07-22-2007 | #7 |
Re: oil leak
Here you go....
[IMG][/IMG]
07-22-2007 | #8 | |
Re: oil leak
Thanks Jerry, in this case your picture is worth a thousand words.
07-23-2007 | #9 | |
Re: oil leak
There are no limit's mans ingenuity, just as mans ingenuity will never conquer the forces & behavior of this planet...Smokey Y. |
07-23-2007 | #10 | |
Re: oil leak
