Old 07-14-2007   #1
tomcat
tomcat's Avatar
Default Nikasil Coating
All,
Was the Nikasil Coating ever used on the cylinder inner walls on the LT5 engines?
Manfred E...........
1991 #906
tomcat is offline   Reply With Quote
Old 07-14-2007   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Nikasil Coating
Originally Posted by tomcat
All,
Was the Nikasil Coating every used on the cylinder inner walls on the LT5 engines?
1991 #906
Yes, the LT5 used Nikasil-plated, aluminum wet liners.
See http://zr1netregistry.com/LT5tech.htm
Old 07-14-2007   #3
tomcat
tomcat's Avatar
The Nikasil coating which at least on the Jaguars Forum is "Nikasil is a kind of ceramic material" prone to corrosion due to sulfar in gasoline, in the Jaguar XKR & XJR 1997-2000 is when the issue occured for them. Jaguar quit using Nikasil with the mid 2000 models.
Glad we used aluminum.
Thanks for your reply
Manfred E..........
1991 #906
Old 07-16-2007   #4
lbszr
lbszr's Avatar
Manfred E..........
1991 #906
Were the Jaguar cast iron coated with nikasil?
Old 07-20-2007   #5
tomcat
tomcat's Avatar
Yes, the Nikasil coating was used on XKR & XJR engines from 1997 to mid 2000.
Manfred E......
91 #906
