Old 09-23-2004   #1
Hub
Default backup lights
Sorry, that's me again...
My last electrical problem is the backup lights which are not working anymore...
I saw the help on the website but need your comments about the way to proceed (switch on the gear box)... is it so hard to fix?
Thanks again for your help and drawings or pics you could have on this.
Hub
Hub is offline   Reply With Quote
Old 09-23-2004   #2
8388
Default
You have to move the slave cylinder out of the way in order to get to it, only two nuts hold it in place. I had to cut up a 12 point socket and weld it unto a wrench, because you have to reach inward towards the tranny in order to get to the switch. I should start marketing this tool, since it makes the job a breeze, and there's literally thousands of these switches out there, that are about to fail.
8388 is offline   Reply With Quote
Old 09-24-2004   #3
Wayne
Wayne's Avatar
Default
Please explain just how you made the tool so the rest of us can benefit from it. Unless you really are going to market it
Cya Wayne
1990 ZR-1
Silver/Black
#269 The car Mom saw 183 in
Wayne is offline   Reply With Quote
Old 09-24-2004   #4
Default
The back-up light switch can be changed using common tools bought at sears. Buy a 12 point deep socket, cut it off so it is just long enough to reach the bottom of the hex on the switch. Buy a 3 piece socket cap set from sears (these are adapters that plug into the socket that let you turn the socket with a wrench). Put the socket cap into the socket, put the socket on the switch after removing the electrical connector from the switch, and break the switch loose with a wrench. Remove the socket from the switch once the switch is loose enough that you can turn it by hand. There is not sufficient room to leave the socket on the switch and screw the switch all the way out. Before removing the switch you will need to take the slave cylinder loose from the bell housing and move it to the side to give you more room to work. There is also a small clamp on the line leading to the slave cylinder to remove to allow the slave cylinder to move easier. The piston in the slave cylinder is spring loaded and will extend when you remove the slave and you will have to re-compress the spring when you re-install the slave.
Tom is offline   Reply With Quote
Old 09-24-2004   #5
Wayne
Wayne's Avatar
Default
Thanks alot Tom
Old 09-24-2004   #6
8388
Default
Old 09-24-2004   #7
Wayne
Wayne's Avatar
Default
Tom:
What size is that socket?
Guess I could look and not be so lazy
Tks Wayne
Old 09-25-2004   #8
Default
Do some search on posts. I can't find his email but there is a person that will loan a custom made tool that he loaned to me for free. He does it to help out other owners. If I can find it I'll post the info. He did not want anything for the loan of tool but I sent him some goodies from Hawaii to show my appreciation. It sure did make it easier to remove the back up switch for replacement.
Old 09-25-2004   #9
Default
Here is the great ZR-1 guy with the tool to loan.
Al Kinder (USAZR1@aol.com)
Old 09-28-2004   #10
Default
22 mm, I bought the new switch, measured it and then went and bought the socket when I had to replace my backup light switch.
