Old 1 Week Ago   #1
Blue Flame Restorations
Default Stainless Braided Flex Lines
Does anyone have the correct part number for Russell stainless steel braided flex lines or any other companies member?
Thanks
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 1 Week Ago   #2
Default Re: Stainless Braided Flex Lines
See 8th post in Solutions 👍
Summit Racing has SS Braded Aeroquip Hose in 10 ft and 20 ft lengths 👍
Old 1 Week Ago   #3
scorp508
Here's the direct link.
https://zr1.net/forum/showpost.php?p=148468&postcount=8
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite
1994: ZR-1 #150, Admiral Blue / Black
2015: Z06 Coupe, Z07, M7, Arctic White / Red
Old 1 Week Ago   #4
Are you referring to Oil Cooler Lines, brake lines, Clutch Slave, or just Russell brand lines/fittings.
The solutions link needs updated if the SecondChance & JeffVette Oil cooler adapters are still no longer available.
Oil Cooler Lines are available @ Jerrys Gaskets in Braided Dk Gray Kevlar or SS.
Old 1 Week Ago   #5
I am needing brake lines from the caliper to the hard lines.
I know Russell makes him but as far as getting the right part number online it seems like it?s every standard brake line kit is is passed off for ZR1
Old 1 Week Ago   #6
In that case.......
The 7th iitem in this post......
Post 41 - ZR-1 (90' and 91') Wilwood Rotors and C4 to C5-Z06 Conversion
The stock Brake Lines were replaced with a Wilwood 220-8338 Flexline Front Brake Line Kit in both Standard 1990 and 1990 ZR1 installation.
Old 1 Week Ago   #7
ScottZ95ZR1
ScottZ95ZR1's Avatar
I have a new set of DRM hoses on the shelf. Also have a set of the Russell hoses. Free delivery if I can hang out in the shop for a bit!
https://www.dougrippie.com/images/th...lines_550.jpeg
Last edited by ScottZ95ZR1; 1 Week Ago at 01:57 PM. Reason: found Russell hose set
ScottZ95ZR1 is offline   Reply With Quote
Old 1 Week Ago   #8
Need brake lines. Flexible stainless braided
Thanks everyone
I plan on putting C6 front calipers on the car as well. That would make the front lines probably call for a different part number?
Old 1 Week Ago   #9
Awesome
Old 2 Days Ago   #10
Starman
Starman's Avatar
Mid-America has one pair left. Could probably get Earl?s on Gasoline Alley to make anything you want, they will need the OEM lines to duplicate the fittings.
Starman is offline   Reply With Quote
