Old 07-30-2024   #1
Bruce Hazell
Default AC Clutch Replacement 1991
Hi All,
Replaced my AC compressor last yr with a new one from Jerrys Gaskets. At a car show this weekend and ac went kaput ...it would appear that the clutch is destroyed..hopefully not the compressor too.
Anyway...Jerrys does not sell the replacement compressor WITH clutch...so I am first looking for a clutch kit to fit the 91 ZR1. There is a parts dealer in Niagara Falls who has one for a 1990 ZR1...and this is the only one I have found so far on my searches.
Anyone know if the 1990 kit will fit the 1991 compressor.
Any other suggestions??
Bruce Hazell is offline   Reply With Quote
Old 07-30-2024   #2
1991 Corvette ZR-1
Default Re: AC Clutch Replacement 1991
I have a clutch kit in the parts bin for a future replacement. It is GPD brand part number 4321248. I believe the description for this one was that is fits the 1990 ZR-1, but as far as I know, there is no difference in pulley diameter from 90 to 95 for the AC compressor. The kit has a new magnetic coil as well, but it also will require some reworking of the electrical connections to plug in to the factory harness. So technically, this does not fit the 1990 model either as a direct drop in, without some work.
1991 Corvette ZR-1 is offline   Reply With Quote
Old 07-31-2024   #3
AndrewL
I went through this last year and posted this thread asking about the clutch like you have: https://zr1.net/forum/showthread.php?t=35084
I just updated that thread with how part number 4321248 worked on my 91.
AndrewL is offline   Reply With Quote
