Old 2 Weeks Ago   #1
Survivor69
Default How to reset FX3 cod eon 1994 ZR1
I have a 94 ZR1 and I am trying to reset the selective ride control code dash light. I have read that I need to jump pin 3 and 4. Does someone have a schematic or step by step how to reset the light? Thanks!
Survivor69 is offline   Reply With Quote
Old 2 Weeks Ago   #2
Starman
Starman's Avatar
Default Re: How to reset FX3 cod eon 1994 ZR1
Sometimes the check at start up is a bit slow as the system looks for the shock actuators to fully cycle. When I start my 91, I turn the key on, but do not start it until the SRC light goes out.
Starman is offline   Reply With Quote
Old 2 Weeks Ago   #3
secondchance
SRC light will not turn on once malfunction has been addressed. I never tried resetting but even if you clear the code, unless the repair has been made, SRC light will light up again.
Also, if the ignition is turned on more than 5-6 times (not sure of exact number) without moving, SRC will light up.
