im getting a bit of a hesitation i guess is how you would explain it. when the car is at idle, and you floor the gas, it seems to stumble for about a second and then shoots back up. its like its going to die for just a split second. the rpm's actualy go down when you floor it and then right back up. i have tried pressing the gas pedal slowly to raise the rpm's and it does it with no problem??? this is in neutral or in gear taking off it does it. just started this a bout a week ago. anyone incounter this? any ideas where to look?
just went down and was tinkering with it a bit. i had the hood up this time and was flooring it from idle and its still doing it, with a little backfire to boot. and i can realy smell its running rich. there is a heavy gas smell on the exhaust??? i have a haibeck chip and i thought that laened out the f/a mixture??
![]() ![]() Join Date: Mar 2006
my guess, injector's leaking.
not the greatest of news. Are yours original? either replace em soon. or just....kill yourself. ![]() |
#4 | |
Think about checking your plugs.
#6 | |
#7 | |
![]() Join Date: Aug 2005
Just for the heck of it reach behind the plenum and make sure the vac lines are still attached to the fuel pressre regulator and the map sensor. I have seen backfires blow these lines off. Charlie |
![]() Join Date: Dec 2004
I'm with the "check the wires" camp.
![]() Another random thought crossed my mind. Could the TPS have a hand in the hesitation? I'm thinking that it's a rehostat type sender and what if it gets something funky on the continous contact? Maybe throw the scanner on her and see what's up with the signal??? Good luck with this! ![]()
#9 |
![]() Join Date: Feb 2007
I have the same problem on my 91' I have no idea what it is either. Please post your outcome...that would be a major help. My car smells like it's running really rich after I put my B&B on. No chip...stone stock.
ArcticZR1 91' White/Red #858 |
#10 |
I would take a look at the plugs and the gap, my cars did the same thing it was the plugs and the proper gap I used Ngk Irid. problems gone......
RAY
[FONT=Century Gothic][SIZE=5][COLOR=black][I]:dancing[/I][/COLOR][/SIZE][/FONT] Last edited by BBBAD94ZR1; 06-19-2007 at 11:23 AM. |
