Old 06-12-2024   #1
chesnut
Default 1992 Upper Radiator Shroud Removal
Help with upper radiator shroud remova;
- all fasteners removed - see attached screenshot
Upper radiator shroud seems stuck to radiator.
When I pry up on driver's side flange with some force, the shroud will raise 1/2 inch, but that's it.
Did I miss some fasteners or ?
Thanks in advance,
Gary
File Type: jpg 1992 ZR-1 Upper Radiator Shroud Removal_061224.jpg (43.9 KB, 17 views)
chesnut is offline   Reply With Quote
Old 06-12-2024   #2
Subfixer
Subfixer's Avatar
Default Re: 1992 Upper Radiator Shroud Removal
Did you get the 3 on each side? 8mm head.
Also 2 on each side down by the frame rails.
Sent from my Pixel 4a (5G) using ZR-1 Net Registry mobile app
2021 Audi RS5, 2.9 V6 Twin Turbo, Auto, Black, Black
Old 06-12-2024   #3
chesnut
Subfixer,
Thanks for info.
Just found the drawing that shows 3 on each side - see screenshot.
Question - how in the heck do you get to those? Do you have to take the air pump off on the driver's side?
Thanks,
Gary
File Type: jpg 1992 ZR-1 Upper Radiator Shroud Removal_061224_p2.jpg (46.3 KB, 9 views)
Old 06-12-2024   #4
Subfixer
Subfixer's Avatar
Yes. I had to remove the air pump to get to mine
Old 06-13-2024   #5
chesnut
Subfixer,
Any secret steps/processes to removing the air pump?
Don't have a lift, so I'll have to jack it up and use a jack stand.
Thanks,
Gary
Old 06-13-2024   #6
Subfixer
Subfixer's Avatar
If I remember correctly, it was just a couple of bolts. I disconnected everything from the top. Remove the hoses from the pump. It doesn't need to move far.
Old 06-14-2024   #7
chesnut
Subfixer,
Thanks. Will give it a go.
Gary
Old 06-15-2024   #8
chesnut
Subfixer,
How did you go about getting the 3 8mm screws/bolts out on the passenger side?
Did you use a flexible long extension or ?
Those screws/bolts are very akward for this old man to get to.
Your help is much appreciated. Thanks,
Gary
Old 06-15-2024   #9
Subfixer
Subfixer's Avatar
Yes. Very hard to get them. I used a small 8mm wrench for the ones I couldn't get with a 1/4 " drive ratchet, extension and universal joint.
Old 06-15-2024   #10
Subfixer
Subfixer's Avatar
Once all the bolts are out, the next challenge will be getting it out from under the AC and oil cooler lines.
