Old 05-19-2024   #1
scorp508
Default Code 61 with secondary system removed?
My 1994 has the secondaries system deleted, yet still popped a code 61. I'll dig through my FSM, but any ideas on what to look for? I cleared it and will see if it comes back. Thank you.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite
1994: ZR-1 #150, Admiral Blue / Black
2015: Z06 Coupe, Z07, M7, Arctic White / Red
Old 05-20-2024   #2
Default Re: Code 61 with secondary system removed?
Have you changed the PROM or the BIN in the PROM or is is this how you got it?
Old 05-20-2024   #3
scorp508
How I got it. I read the program off it for safe keeping but haven't changed anything yet.
Old 05-20-2024   #4
scorp508
I confirmed in TunerPro both...
"Port Throttle System Diag. (Error 61)"
"Port Throttle Vacuum Dag. (Error 56)"
Are both enabled in the BIN. Should one or both have been disabled?
The tables...
"Port Throttle Opening Point vs. RPM"
"Port Throttle Closing Point vs. RPM"
.... are both entirely set to 0% TPS, which looks correct given the secondaries are removed.
Old 05-20-2024   #5
tpepmeie
scorp, those diagnostics are looking for min and max voltages at the port throttle vacuum sensor. They need to be changed if you have removed throttles and vac sensor.
Todd
____________________________________
*** our email address has changed!
info@pepmeierengines.com
pepmeierengines.com
Friend us on Facebook too: www.facebook.com/profile.php?id=100011443683384
Pepmeier Engine Development
Old 05-22-2024   #6
Raykahn
Raykahn's Avatar
56 and 61 should both be disabled (not selected) if your secondaries were deleted.
Raykahn is offline   Reply With Quote
Old 05-29-2024   #7
Young1
Young1's Avatar
Has your prom chip been reprogrammed for secondary delete by Marc Heibeck?
Steve Young
Second Owner
SOLD
SOLD
Old 05-30-2024   #8
scorp508
Not by Marc, no. I suspect this was just a simple miss by the last person to tune it as they're definitely familiar with secondary deletes. The secondary port open/closed table is zero'd out, but these flags were missed.
I'll burn a new one and see how it does. Waiting on USPS to deliver a few more EEPROMs as I can't find my stash.
Old 05-30-2024   #9
tpepmeie
I recommend not just turning the flags off but changing the voltage thresholds themselves also. There is a max vac for open and min for close, if I recall . I don?t have my notes right now though.
Todd
pepmeierengines.com
Old 06-03-2024   #10
Here's the values.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
